Full Throttle Cleaning
I am about to take my 1995 Maxima GXE in to have a full throttle service done: Extensive cleaning of the Fuel Rail, Injectors and Throttle body.
I have been told that to do this, they connect through either the PCV Valve, or the Schrader Valve. Do Maxima's have Shrader valves on the Fuel Rail? I want to make sure they connect where the Injectors will be the first thing that get cleaned.
Can anyone offer any insight as to where I should tell them to connect to ensure the injectors get hit first.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Originally Posted by SonicDust187
How much for MotorVac, and what exactly does it do?
i asked my mechanic, he said his charge for it starts at $120-130 depending on a car.
edit: found this link: http://www.impalassforum.com/cgi-bin...&f=33&t=002148
from the site in my other post (last page)
NJ Voorhees Voorhees Shell (856) 346-9468 http://www.maxexchange.com/voorheesa...uel_system.htm
NJ** Mt. Laurel Everett and sons Auto 856 778 3535 Via SSGUS
NJ Pennsville Chips Auto Ctr (609) 678-4066 http://www.njcool.net/Directories/C/...s/AugTip2.html
NJ Stewartsville Louis Garage 908-479-1050 http://www.louisgarage.com/services.htm
NJ Garfield Joe & Steve Auto (973) 772-8736 http://www.joeandsteveautomotive.com/
NJ** Colonia Westlake Auto (732)574-2334
NY Amherst Buffalo Muffler (716) 834-2296 http://www.buffalodiscountmuffler.com/carbonclean.html
NY** Brooklyn Sal-Be Auto Repair 718-449-5979 Ask for Frankie per Nihlist
NY My car needs fixing 718-442-7676 http://www.mycarneedsfixing.com/service.html
NY Ozone Park Bell Autocare 718-641-0615 http://www.bellautocare.com/services.html
NY Buffalo Russo’s Auto (716) 855-0490 http://www.buffaloathome.com/pro/russo.asp
NY Massapequa Auto Tech Diagnostic 516-795-4411 http://www.autotechsite.com/
NY Rochester Kurts Garage 585-266-4992 http://www.kurtsgarage.com/
NY** Rotterdam Carman Service (518)381-9107 http://www.carmanservice.com/
NY** Staten Island Front End Specialist Corp .(718) 442-7676 Ask for George – via LarryCigar
Thanks for the reply.
I'm just wondering if Maxima Fuel Injection Systems have Schrader valves on the fuel rail.
Any insight would be appreciated greatly.
Thanks in advance.
Thanks in advance.
ok, did this on march 13th on my 96 with ~93,000 miles. cant say the car was shaking prior, it was running as usual, but i think i thorough wash of the engine (valves, injectors, etc.) would only be beneficial.
my mechanic has the machine, and i ended up doing everything myself pretty much
spent about 30 minutes unhooking the fuel lines (theyre hiding close to the fuel filter, below the intake manifold). NOT the easiest location to work with. the biggest thing was to take off the rubber fuel lines without ripping the whole metal fuel rail bundle (some penetrating spray and brute force did the trick). hooking up the hoses from the motorvac machine to the car wasnt bad at all, and the whole cleaning process took about an hour (20 minute injector cleaning, and 40 minutes running the car to clean the engine). after everything was done, it took about 5 minutes to hook everything back up
the only downside is my hands were smelling like gas, so i had to thoroughly wash them. i cant honestly say there was a noticeable change, maybe just a bit more smootheness. my mechanic charges about $130 to do this.
220k+ A32
Sep 23, 2015 03:38 PM
JoshG
51
Sep 21, 2015 10:41 PM
