Idle problems!!!!!!!!! GRRRRRRRRRR
ok i cleaned out my intake manifold and my throttle body (pics on page 2 of my web site) the car was down with out the battery hooked up for a week, i didn't have time to put it back together. but when i did the idle would jump up and down from time to time at a normal operationg temperature, it would go down to about 700 and it sounds like it would stall but it never did. And after a little bit of trying to chocke its self it goes up to 1000 or so and then after 30 seconds it would go down again to 700 and of course it would try to stall. my cel is on and when i tried to pull up the codes i never get them, sooo some one please help me, i don't like driving the car in this kind of condition, i also found a sensor that was laying on the tranny, it plactis with a rummber thing around it....so i just plugged it into my cai, is that where it goes?????Thanx for your help!
well the idle on our car is very "touchy" in first place
try connecting all the sensors and then pull any codes if they show up.
the sensor you are talking about is the intake air temperatrue sensor - the ECU is using it along with other sensors to calculate air/fuel mixture ratio at engine start up
My idle after TB cleaning is still quite high - about 950rpm in N and about 650rpm in D - but she is steady *** hell !!! and i like it that way - no vibration or shaking
Nick.
Nick.
"A broken or loose TPS can cause intermittent bursts of fuel from the injectors and an unstable idle because the PCM thinks the throttle is moving. A problem with TPS or circut will set diagnostic trouble code."
So check the car for codes.
Originally Posted by CystumMax
Sounds like a bad TPS( Throttle position sensor) This sentence comes from the Haynes manual.
where is it located, i don't have my hanes manual with me, but i did drop a part that goes on top of the manifold..i donno what u call it but its sittin on the manifold a little bit to the left of the cruise control housing that's mounted to the firewall, would that be a problem or is it something else.....how can u check the if the tps is bad....once i find it.....im gonna pull up the codes this weekend and il post them if i can get them.... thanx for your help.
Ok it is mounted on the side of the throttle body and connected to the throttle shaft. If you have automatic it will have two wire conector going to it. if not you would only have one going to it. if you opened the screws and try to clean it and you could have changed the throttle adjustments, this could causing you this problem.
Nick.
Nick.
i don't think i messed with the throttle body at all i just left it as hole and cleaned it on the car...
that big thing with 3 bolts that has like 4 sensors on it on the back of the manifold right?? oh and im and im a manual
ok if you are maual, you only have one wire going to it. I don't think thats what is you are taking about.
Ok go to this link, go down the page and they have picture of what TSP looks like.
but in your case it could be something diffrent. it could be also bad coil pack or dirty injector, i would recommend check for the code.
http://home.earthlink.net/~maxfaq/maintenance.htm
97_GXE
20
Sep 17, 2015 08:12 PM
lrb6805
Sep 17, 2015 04:49 PM
