Useful web calculators for FI guys
Old Feb 26, 2004 | 09:37 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Turbo power: Calc a turbo engines power
Compression Ratio: Calc engine compression ratio or combustion chamber volume
Turbo Compression: Calc engine compressioin ratio under boost and recommended octane necessary
Turbo Match: Match a turbo for your desired setup
Turbo Map: Find a good compressor flow map for your desired setup
Drag Racing: Find ET, HP, MPH, and Weight
http://www.turbofast.com.au/javacalc.html
Selecting the Proper Fuel Injector
Converting between lb/hr and cc/min
Flow rate of injector at new fuel pressure
BHP, BSFC, DC, fuel pressure-->cc/min required
Actual BSFC used based on bhp from dyno
http://www.rceng.com/technical.htm
Old Feb 26, 2004 | 09:38 AM
IceY2K1's Avatar
I use these all the time vs. busting out my calculator or excel.
Add any more you guys have found useful.
Thanks.
Old Feb 26, 2004 | 09:42 AM
ilumo's Avatar
Thanks.
I use the RCENG link a lot, and then use excel some too You wouldnt happen to have a link with all that turbo info, but for the SC wouldja? thanks
Old Feb 26, 2004 | 09:48 AM
Bags's Avatar
VG Ridah's Biatch Hoe
GREAT INFO
Old Feb 26, 2004 | 10:02 AM
IceY2K1's Avatar
What kind of stuff for a SC?
Everything above applies the same to a SC EXCEPT picking a compressor map/turbo.
BTW, use a BSFC of 0.55 for a SC vs. 0.60 for a turbo.
Old Feb 26, 2004 | 10:40 AM
Bags's Avatar
done and DONE
Old Feb 26, 2004 | 10:44 AM
IceY2K1's Avatar
Bags...I was going to start another thread with "useful links".
Lets keep this one just "useful calculators"...if you don't mind.
Originally Posted by bags533
Most of these are from supra forums.. but theyy will work for us
A/R Ratio info
http://www.supraforums.com/forum/sho...threadid=90350
where to buy 100 OCTANE gas
http://www.racegas.com/gt100locals/default.asp
how to find a boost leak
http://www.supraforums.com/forum/sho...threadid=78644
spark plug pics and descriptions of fouling and other stuff. GREAT HELP
http://www.gnttype.org/techarea/engine/plugs.html
Old Feb 26, 2004 | 10:58 AM
IceY2K1's Avatar
I can't move/delete anything in here...not my forum.
If you could, START a new thread with them and then delete these. Or I'll do it once I get mine together, so we can have BOTH sticky'd.
Old Feb 26, 2004 | 11:03 AM
IceY2K1's Avatar
I<3 A32's
Sep 10, 2015 11:07 AM
dcam0326
Sep 7, 2015 07:26 AM
Max139617
Sep 6, 2015 06:02 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
