Those that have changed their fuel filters in 00-01 Maximas..
did you notice any difference in mpg? Does anyone have the write up and how much does the filter cost from DaveB? I plan to do this along with my brakes and spark plugs
over spring break.
over spring break.Thanks
Fuel Filter does not need to be replace according to the owner's manual due to the fact it's in the fuel tank. Nissan consider a maintanence free part. If you want, it's gonna be a quite a task to replace it. The part only cost 3 bucks for it. As far as getting to the tank, you have to remove the rear back seat. it's a very lenghty task. There was a write up somewhere on the post. It's not worth doing it if you don't want to get fuel smell and a mess. Yet, even break a connector on the fuel floater.
I've done it. I even have a writeup with some pics from when I broke the fuel sender unit's supply line on the inside.
I didn't notice any difference in fuel economy, but did notice a DRAMATIC night-day difference in power. I guess mine was in horrible shape.
Check for any threads started by me... I started one which ended up in a writeup.
when i went to change my fuel sender nissan told me that they did not sell the filter without the pump and it was 250 dollars. i also broke my sender which needs to get changed.
Thats what the dealer will tell you, but it can be bought from DaveB separately.
I changed mine last night, its not that hard of a task at all, just for me I got a small issue because I have the Walbro 255lph pump in there which is technically 1/8" longer than the stock pump. So its causing me some problems at the moment.
Dixit
Dixit
Originally Posted by Cesar
I do not thing a fuel filter would be $3. Eventough it is considered a maintenance free item it should be replaced when all other resources have been met ie: air filter, fuel injectors cleaned, etc. This should be left alone if possible (IMO)
I did it also, its not hard...do it when the gas light kicks on and dealing with fuel will be kept to the utmost mimimum.
From DaveB I believe the FF is like 12 bucks and the Gasket (PLEASE REPLACE IT) is like 9 bucks.
I was chasing a fuel mileage issue and my FF was NASTY. THe FF was the trick. Just because its in the fuel tank does not mean it does not need replacing. Nissan just has a bad design :gasp:
Here it is. I thought I put it in. http://forums.maxima.org/showthread.php?t=276627
Originally Posted by Y2K1GLEMAX
do u have a pic of the sensor?where can i get a new one and how much would it cost?
The "sensor" is the whole top housing, which includes all the soldered wires/connectors/etc. It does not include the fuel return hose which snakes down to the bottom, nor the bottom chamber, nor the fuel pump.
I broke the fuel supply inlet on the inside of the "sensor" housing, that's why I posted that thread (the first pic in my first post is exactly that). I think it was $85 or so, can't quite remember
No, you must buy it through a Nissan dealer.
You need the Fuel Filter ("fuel strainer assembly"), and replacement O-ring which goes around the lip of the fuel tank (to ensure proper sealing, since the O-ring gets crushed)
About $22 shipped from DAVEB (Dave Burnette) at South Point Nissan. You can find his contact info in other threads.
Originally Posted by aussie983
this might be a stupid question, but how can you tell when your fuel sensor isnt working? does it throw a code?
i thought they lasted forever. but nothing lasts forever, when it comes to nissan
The Wizard
24
Oct 1, 2015 08:47 PM
JoshG
51
Sep 21, 2015 10:41 PM
aminus21
Sep 12, 2015 04:53 PM
sdotcarter
Sep 2, 2015 09:53 PM
