6 speed diff. conversion done
Old Feb 29, 2004 | 09:22 AM
SR20DEN's Avatar
VQ Wizard
http://www.poweredbynissan.com/images/2K2Max/RS6F51H/
I had to replace my broken clutch so I converted the spare tranny I had but installing the helical differential from my existing tranny. It was a direct drop in after I managed to remove all the gear assemblies.
Old Feb 29, 2004 | 09:34 AM
PoLo's Avatar
2-Wheelin it...
first, congrats....applause indeed
but where does the burger king come into play.
Old Feb 29, 2004 | 09:48 AM
SR20DEN's Avatar
VQ Wizard
Nourishment for the laboror(s).
Old Feb 29, 2004 | 09:52 AM
StrongIsleMax's Avatar
Have you thought about using the final drive from a 2k4 6 speed. It was changed to account for the larger wheels on the 2k4, but in a 5th gen it would shorten the ratios.
Old Feb 29, 2004 | 11:12 AM
6spmax's Avatar
Was the spare tranny an HLSD or open differential tranny? I've heard that the casings for each are two different sizes.
Old Feb 29, 2004 | 11:17 AM
Stereodude's Avatar
Well, my dealer tried to tell me I had the open model because I have the same casing as the open tranny. Of course the Metal plate under the hood says I have the HLSD. I'd say they probably have the same housing. I'm sure SR20 can clear this up.
Old Feb 29, 2004 | 01:37 PM
6spmax's Avatar
See if your car came with the drilled metal pedals. Non HLSD cars have regular rubber pedals.
Old Feb 29, 2004 | 01:39 PM
Blu's Avatar
Blu
the tits
The casings are the same size. Basically all he did was remove the open and drop his HSLD in and keep the gears from the replacement open tranny. I was there the night of the swap and snapped the few pics available.
Old Feb 29, 2004 | 05:17 PM
SR20DEN's Avatar
VQ Wizard
Yes there is no difference in size between the bearing races of the HLSD vs. the open differential. Everyone is geting it confused with the older transmissions open differential vs. the VLSD which does have a much larger bearing race.
Old Feb 29, 2004 | 05:24 PM
6spmax's Avatar
So then why is it so fu(k!ng hard to get a dealer to install the Nissan HLSD? It sounds like a relatively simple job.
Old Feb 29, 2004 | 05:37 PM
SR20DEN's Avatar
VQ Wizard
Because half of them are ignorant of the facts and the other half are too lazy to do any abnormal work. Nissan techs are trained by their own salary to do as little as possible and only accept the easy jobs that pay well. A tech would probably lose his **** on this job salary wise if it was the first one he did.
Everyone just needs to send me this kind of work. I won't b!tch about voiding your warranty.
Old Feb 29, 2004 | 05:42 PM
SR20DEN's Avatar
VQ Wizard
And it does none of you any good to run to your dealer and tell them "well some guy on the internet did it". They'll just trash talk you behind your back, I know because my co-workers do this same crap to our customers. This is one thing where I defend the customers on, the guy on the internet is not always wrong.
Old Feb 29, 2004 | 05:50 PM
SR20DEN's Avatar
VQ Wizard
Fark no!! If anything my first gear needs to be taller. If the final drive were any shorter I would have to use second gear as my first gear. And I can already roast second gear from a standstill. I can almost launch the car from second gear now.
Old Feb 29, 2004 | 07:55 PM
Fezzik's Avatar
OK OK. Sorry, but I am a bit confused. and would like clarification.....
So anyone with a 6MT 2k2 or 2k3 can pop open their tranny... put in the helical differential with all the existing parts, and poof, you now have HLSD?
Old Feb 29, 2004 | 08:49 PM
SR20DEN's Avatar
VQ Wizard
I fail to see what is confusing. I have explained this dozens of times and even posted some pictures of that very task.
Old Feb 29, 2004 | 08:51 PM
6spmax's Avatar
I would also like to know how much time installation of the HLSD takes and what is involved.
Old Feb 29, 2004 | 08:58 PM
SR20DEN's Avatar
VQ Wizard
I think i can do the job in about 2+ hours once the tranny is on my bench.
It requires basically dissasembling the whole thing and it's not fun. I don't recommend it for anyone that isn't very mechanically inclined. This tranny is much more difficult to take apart than the older 5 speed trannys.
Old Mar 1, 2004 | 02:23 AM
Triple8Sol's Avatar
I miss the .org!
2+ hrs...so adding the time to pull the tranny, what's the total time for a job like this?
Old Mar 1, 2004 | 04:45 AM
cmr72's Avatar
What are your thoughts on this "phantom grip" I have been reading about?
Old Mar 1, 2004 | 05:39 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
Sweet man. I'm sure you'll like having that LSD...
Old Mar 1, 2004 | 06:17 AM
Blu's Avatar
Blu
the tits
Matt had HLSD stock but he got a deal on an open differential tranny that only had 1500 miles on it that was replaced by the dealer for bearing whine. His gears were screwed in his current tranny and wouldn't shift into 6th and when it did it was a PITA to get out of 6th. He basically just swapped his HLSD into the open diff. and used the casing and gears from the open diff.
Old Mar 1, 2004 | 09:34 AM
Tommy Boy's Avatar
Finally I have my answer to the no-LSD to HLSD swap!!!!!... SR20den Please give me a quote on what it will cost to R & R the diff for my 02.... I could drive down there on a Friday, R & R the diff on Sat and drive home Sat night or Sunday. Have any idea on the price of a HLSD from Nissan??
Old Mar 1, 2004 | 09:39 AM
6spmax's Avatar
Let us all know the price if you don't mind.
Old Mar 1, 2004 | 03:31 PM
SR20DEN's Avatar
VQ Wizard
I will check my prices from the dealer but I'll tell you now the thing could still cost about $800+ for the parts alone. You can all contact DAVE B to see what he says. Also by this weekend I will have some other information that will be useful if it works.
Labor to remove and install the tranny will be about three hours because mine was the first 6 speed I have done, so im not fast on them yet. These are also more of PITA to remove from the car than the 5 speed was from the 4th gen.
Old Mar 1, 2004 | 03:54 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Hmmnnn...any chance this shortcut for installing a Quaife would work?
http://www.vqpower.com/v2/modules.ph...&pid=42&page=3
Old Mar 1, 2004 | 04:32 PM
DAVEB's Avatar
I can get the HLSD unit for $449. My catalog says the diff bearings and ring gear are the same. Looks promising!
Old Mar 1, 2004 | 06:31 PM
kklier's Avatar
Great JOB!!
Old Mar 1, 2004 | 09:39 PM
Tommy Boy's Avatar
So, 3 hours to R & R the trans and another 2-3 to R & R the diff. So tha't 5-6 hours to do complete job. Is that a correct figure for the job SR20DEN? What are your labor rates?
Dave B...... Thanks for the pricing info bro!!!! I'll be in touch!!!
We'll have to get one of the mods to make this a sticky once we get pricing worked out!!! We can't be the only ones wanting/curious to do this.....can we?
Old Mar 1, 2004 | 09:50 PM
SR20DEN's Avatar
VQ Wizard
That is far better than I had hoped for.
I will also need to check on the availibility of the shims and if I am going to be doing more of these I will need to stock a variety of them.
Old Mar 2, 2004 | 06:33 AM
Tommy Boy's Avatar
Talk to me goose...What's the price????!!!!!! I've got to start to budget for it.
Old Mar 2, 2004 | 07:47 AM
DAVEB's Avatar
I just checked with Nissan, there is currently only one HLSD unit in the U.S. Who's going to be first?
Old Mar 2, 2004 | 08:15 AM
studman's Avatar
I wish it was me. SR20DEN, I'm about 7 hours away from you. I'd love to give you the business too, but was wondering if once you figure it all out, if you could post up a parts list, etc that was needed. I know of several people in my area that want this done, but I don't think each and every one of them want to drive to Charlotte to do this. I've got a connection here in Orlando that can do the work for sure, but they'd just need more information to know what else is involved in doing the job - any pointers, tips, tricks, etc.
BTW... awesome job taking this upon yourself. My PR motor mounts finally let me put the power to wheels, so now I need the LSD to help apply it evenly. Keep me posted.
Old Mar 2, 2004 | 04:23 PM
SR20DEN's Avatar
VQ Wizard
I got the same price of $449 for the differential and about $3 and change for each thrust shim which is application specific. Also it makes no difference to me if you get that through me or Dave because that is already at wholesale cost.
The guys at the shop where I work all think I am selling the job too cheap @ $350 to cover my labor and shop fees but that is what I am going with on this one. I am certain the dealership or my work would charge much more than that to do this job.
Old Mar 2, 2004 | 04:29 PM
SR20DEN's Avatar
VQ Wizard
I am not opposed to anyone shpping me their transmission if they want to have this done.
Old Mar 2, 2004 | 04:49 PM
MardiGrasMax's Avatar
I'd charge $350 for the bench work alone.
Old Mar 2, 2004 | 05:33 PM
sorcereur's Avatar
That is a good price. I'd charge $350 just to pull the tranny out and putting it back in, then another fee for opening the tranny and doing the rest.
That's a good price for anyone interested in this.
Good job SR.
Old Mar 2, 2004 | 08:16 PM
Tommy Boy's Avatar
I think that's an outstanding price SR20DEN!!! I should be ready to go for the install in a month. I need to do a little saving and coordinating my schedule in order to do this in a weekends time. Is this something you can do on a Saturday? I will probably drive down on a Friday have you do the swap on Saturday and hopefully return home on a Sunday. Does this sound agreeable to you?
Old Mar 3, 2004 | 09:29 AM
SR20DEN's Avatar
VQ Wizard
Yes that's the best way to do this. However if you order the HLSD through me I need payment for it up front.
Old Mar 3, 2004 | 10:14 AM
IceY2K1's Avatar
I was quoted $700 for the Quaife install, but it included a "FREE" clutch/flywheel install since he's already got it all apart.
Anyways, $350 is a steal~!
Wish I was closer to NC.
Old Mar 3, 2004 | 09:20 PM
Tommy Boy's Avatar
That's cool with me SR! As I get my sh*t together I'll PM you and work out the details on a date and time. With a new baby in the house, I have to plan and budget accordingly!...... I definately want to get this done!!!!!!
