damn warping brake rotors
does anyone else have this problem? i got my rotors resurfaced about 10 months ago and my pads replaced, but my car is starting to shake again pretty badly while i brake. anyone have any suggestions on some rotors that won't warp so easily? i heard you can't resurface drilled or slotted rotors and if thats the case then i don't want those. oh and at stoplights my rpms drop to around 500rpm and the whole car vibrates. how do i adjust the idle speed? i remember reading that theres a screw i can turn somewhere. thanks in advance for the help
there's no need to resurface drilled or slotted rotors. it's plug and play application.
try checking for a loose caliper, or even the wheel before stressing about it.. and well if that isn't the problem, get new disc's and brake pads.. not too spendy.. And also could be the calipers, or the fluid level in your breaking system maybe bleed tham also...
good luck
good luck
jason
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
