View Poll Results: Miles when Boost Began
Under 60K
0%
60,000-90,000
0%
90,000-110,000
25.00%
110,000-up
75.00%
Voters: 4. You may not vote on this poll
How many miles when Boost Began ??
Old Mar 4, 2004 | 11:56 AM
matty's Avatar
I have 130K and most likely going to boost in the next few weeks or so...
please vote or write your milage
-matt
Old Mar 4, 2004 | 12:37 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
to avoid another one of these posts which happen every few weeks...skip the guess work and just get a compression test done on your motor(any shop can do it) you obviously seem worried whether it will hold the boost at such at 130k so best best is to have the test done. every motor is different so no matter what ANYONE elses mialage on here was when they started doesn't hardly matter. good luck
Old Mar 4, 2004 | 12:53 PM
ilumo's Avatar
How much would one of these tests run usually? and what does it involve? any idea if you can do those tests at home?
Old Mar 4, 2004 | 01:06 PM
DA-MAX's Avatar
it can be done at home if you have a compression tester(they can be had on Ebay for as low as $10)...all it entails is removing each plug, screwing in the fitting for the tester and testing each cylinders compression...if you can change your own plugs, you can EASILY do this...at a shop I would say more than a 20-30 minute job maybe...so figure in that as labor.
Old Mar 4, 2004 | 06:40 PM
JAY25's Avatar
95 max w/142K and still going. Its about go to to 10PSI next week
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
JoshG
51
Sep 21, 2015 10:41 PM
hozay99
Sep 19, 2015 10:20 PM
hntwhttail
Sep 12, 2015 03:43 PM
