BRAKE Noises + E Brake light - HELP!
Old Mar 14, 2001 | 10:59 PM
MaxMA's Avatar
Me again with some more problems:
Weird sounds come from the rear brakes when I step on the brakes. Had mechanics check it, but they don't know what it is. The noise is related with the ebrake cause when I brake and the sound begins, I play around with the ebrake and the sound stops.
Also, my ebrake warning light (the one in the gauge cluster) does not light up when I pull the ebrake. It is not the light itself cause it does light when I turn the key to ignition position. Is the a switch, sensor, or something that can fix that?
Once again, thanks for the inputs.
Old Mar 15, 2001 | 07:46 AM
dch95's Avatar
Possible problem
Ever had your center console out? If so, check the wire harness on the RH side of the e-brake. Check that it,s connected. Also my FSM tells of a "warning lamp switchplate" giving me the impression that the trigger for the lamp is adjustable. Perhaps that "switchplate" is bent to far out of shape and no longer makes contact.
Old Mar 15, 2001 | 08:08 AM
MaxMA's Avatar
Re: Possible problem
Thanks for the tip. I will try that out today.
Matt93SE
May 24, 2019 02:58 PM
Sport
Jul 3, 2017 05:40 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
egali045
Aug 16, 2015 01:19 PM
Samedi
Aug 13, 2015 04:05 PM
