E-manage help...
Old Mar 7, 2004 | 01:15 PM
MardiGrasMax's Avatar
E-manage help...
I cant get the injecotr duty cycle to display on my E01? I have had the E01 boost controller for a wile, it works fine. I just installed the E-Manage with the injector harness. Is their something special I need to do to get the injector duty cycle to display? I have selected it in the display select and it dosent show? Every thing else works fine, the car runs and drives. I traced all the wires from the E-Manage harness back to the injectors and all the connections are good and the wires are in the right place. Our cars dont have an injector ground so I connected that to the ECU ground, could this be a problem? Perhaps I need to hook an actual computer to the E-manage to change a setting or somthing? Any help is appreciated.
Old Mar 7, 2004 | 02:13 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Matt, now that I think about it...there should be a seperate injector ground...I can't be 100% sure until I look at Coreys car again, but there should be a semi-thick black wire on the ECU harness near the injector wires...I've found that the layout was very similar to the Nissan ECU layouts Greddy provides...most of the "common" wires are relatively in the same places throught the Nissan lineup.
"#E" is where the inj. ground should be, and as best as my memory serves me it was in the same area on the 99 Max harness as the N-3 diagram shows--> http://www.mohdparts.com/emanage/man...-manage_29.JPG
Old Mar 7, 2004 | 03:03 PM
Did you test the wire you hooked up to? Did it just show ground all the time?
Old Mar 7, 2004 | 05:11 PM
DA-MAX's Avatar
nope, didn't test it...but I know we're getting consistent duty cycle readings on the laptop everytime we run a datalog
call up Corey and see if he can check the wire for you...you have a 98 though, so not sure on the difference in position on the harness
Old Mar 7, 2004 | 07:45 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
matt, dont you have a 96 ecu?
Old Mar 8, 2004 | 06:10 AM
Yes, 96 ECU in a 98.
Old Mar 9, 2004 | 06:33 PM
I disconnected the ground for the injectors from the main ECU grouns and it still did not work.
I found another ground next to the injectors wires, same spot as a 300zx; top row nect to #3 injector wire, hooked the injector ground to their and it still dosent show on the E01 display.
Oh Corey, can I use your suport cable for a little while
Old Mar 9, 2004 | 08:59 PM
DA-MAX's Avatar
are you referring to diagram N-3??(http://www.mohdparts.com/emanage/man...-manage_29.JPG)
cause according to the Z32 N-3 diagram the ground should be on the bottom row and I can recall on Coreys harness thats around where I wired it in...it definently was at on the bottom rom of the harness.
so on the harness, in the column you have it in now, what color is the wire at the bottom of the column(bottom row)??
Old Mar 9, 2004 | 09:40 PM
JeffesonM's Avatar
living out of a maxima...
Mardi... I assume you probably have this already, but just in case... diagram of 96 ECU pins
Old Mar 10, 2004 | 06:30 AM
Thanks, I have the FSM but this is allot better!
I have the EM injector ground wire at #108 now, dosent work. It looks like I have a few more to try. #112, #116. #124. Based on what Addie says about Coreys 99 SEL I should use #124. Addie, can you look at the diagram in the link and advise if the harness's look the same on a 99'? Corey, if your out their, can you please look at your harness and verify for me?
One of main reason I bought this was for duty cycle
Old Mar 10, 2004 | 07:06 AM
Redmax's Avatar
Redlinemax Owner
Mardi, i will try and look today during lunch and let you know which is which.
Old Mar 10, 2004 | 07:44 AM
DA-MAX's Avatar
Matt, the 99 ECU harness plug is setup very different from the 96... but if I was going to try any of those 3 wires, I'd say #124 is the best bet cause I know 100% the gorund I used was on the bottom row of the harness, cause it was a kinda difficult to get to!!
Old Mar 11, 2004 | 06:53 PM
So Ive tried 108, 116 and 124, no luck. I dont have a wire for 112. Maybe 10 or 19?
Very frusrating!
Old Mar 11, 2004 | 08:16 PM
JeffesonM's Avatar
Maybe give 25 a shot? Based on that diagram the 96 harness looks most similar to the 95-98 240 harness (N-10B). Don't know the legend for the diagram, but E points to what would be pin 25 on the 96.
Old Mar 11, 2004 | 08:24 PM
DA-MAX's Avatar
Jefferson, make sure you are looking at "#E" and not "E"..."#E" is the injector ground NOT "E", there is a difference. I think you are lokoing at "E" though in the diagram
try 19...and Matt, are you still trying to display it through the E01 or do you have the support cable for a laptop?? did Corey check the wiring for you?? if not I'll be over there tommorow night and I can check for sure.
Old Mar 11, 2004 | 08:35 PM
JeffesonM's Avatar
Thanks, I was looking at E. As I said I don't have the legend so it was just a shot in the dark.
Do you know if Corey has a 99 FSM?
Old Mar 11, 2004 | 08:49 PM
DA-MAX's Avatar
yup...he has one, but when I installed his Emanage he hadn't gotten it yet. actually the reference I did use was excatly like that Jim Wolf PDF you posted for the 96(except it was for a 99). we got it from a buddy who works at an auto shop. if I had it in front of me now, it might really help get this solved, but its in Coreys garage which is why tommorow I can check, or even post it up to compare
Old Mar 11, 2004 | 09:02 PM
JeffesonM's Avatar
Wow, if you could scan that I'd be the happiest man alive! jmerchan@hcsus.jnj.com and I'll host it.
Old Mar 14, 2004 | 09:19 AM
DA-MAX's Avatar
Matt, did you see this:
from Joel on the mailing list:
"ok everyone having this problem go outside and play =] it will show duty cycle after you "confirm" the maps on the PARAMETER screen on the E-01. hope this solves everyone's problems. keep me posted
Jeffson: I have the print out, its a little ragged and oil stained, but I'll scan it best I can...it still shows where I hooked up the coils and injectors though! I'll email it to you later
Old Mar 14, 2004 | 01:19 PM
DA-MAX's Avatar
Jeffeson, check your mail in a few minutes
anyone else who wants to host or just see the 99 pinout alreay labled for a E-manage install on a 99+ email me addaea2002@yahoo.com
Old Mar 14, 2004 | 02:07 PM
JeffesonM's Avatar
Thanks a bunch! Here's a link to the full-size pic: http://www.doubleshotsindustries.com/max/99pinout.jpg
Old Mar 14, 2004 | 06:32 PM
Im a doofus!!!
I had the RPM wire for the EM hooked to the rear O2 sensor wire. I had my Fields AFC hooked their and I just thought it was the right wire. I noticed that the EM was not seeing RPM when I hooked Coreys laptop up, thanks Corey. Thanks to all who helped!
The good news is it works! I saw a peak of 82% @ 7k rpm w/11psi & 4.4vMAF. I saw 79% @7200rpm w/9psi & 4.3vMAF. 49% @ 7200rpm w/4.4psi (BC off) I did see 100% if I bumped off the rev limiter at 11psi I think its just due to the rev limiter hit. I believe I could maybe run up to 13psi with stock FP, if I crank up the FP to 2 bar I should be able to get 14psi. Woohoo, its gonna be a fun ride to work in the AM trying to get the BC to set 13psi
J&S is quiet the whole time, dam conservative JWT taking the fun outa this, up next is the ignition harness. Anyone got some spare coil packs I can buy LMFAO!!!
Old Mar 14, 2004 | 06:51 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Im a doofus!!!
I have 2 front and 2 rear I am willing to give to you if it will help... let me know
Old Mar 14, 2004 | 07:03 PM
DA-MAX's Avatar
Good job man....get the diodes for the coil packs and you should be fine. Corey was running +1 advance with no probs after we installed the diodes...so far no burnt coils!
Old Mar 14, 2004 | 08:20 PM
Redmax's Avatar
Redlinemax Owner
Congrats Matt!!! Hey I have the diodes here. I can drop off the diodes if you need tomorrow.
Old Mar 15, 2004 | 05:15 AM
If I blow up any of mine I will take you up on this offer! THANKS! Very generous of you!!!
Old Mar 15, 2004 | 05:18 AM
I will take them for sure!
I spiked to 14.8psi @ 4700rpm w/73% DC this morning trying to set the BC to 13psi, traffic was heavy so I didnt get but a few good runs at it, so It didnt take.
Old Mar 15, 2004 | 05:19 AM
BigDogJonx's Avatar
Yeap Matt, I gave Corey an extra set of diodes because I knew you were going to want them.
Dixit
Old Mar 15, 2004 | 06:34 AM
Redmax's Avatar
Redlinemax Owner
yep we wanted to make sure my car didn't go boom before we passed them on
Old Mar 15, 2004 | 10:40 AM
Dixit
Gracias hombre!!!
Old Mar 15, 2004 | 10:44 AM
Bags's Avatar
You have helped me get where I am. I have some extras laying around, they do have 130,000 miles on them, but they all work.
That what we do here, right? Help each other out as best as we can
knight_yyz
Nov 6, 2015 02:34 PM
knight_yyz
Oct 24, 2015 08:05 AM
