2k2 Front Brake Rotor Removal
Old Mar 20, 2004 | 06:23 AM
2k2maxowner's Avatar
Does anyone know if you need a wheel-puller to remove the front rotors on a 2k2? Any instructions would be greatly appreciated.
Old Mar 20, 2004 | 06:40 AM
Cubanato's Avatar
Joo wanna play??......ok we go to war
i dont know what a wheel puller is.....but i can tell you when i did mine...i used some sockets and ratchets to
-J
Old Mar 20, 2004 | 08:41 AM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
just removed the caliper. then took a rubber mallet threw a towel over the rotor and started banging lightly top, bottom, top bottom...until it came off.
I only did this becuase is was on there good..
Old Mar 20, 2004 | 08:53 AM
SR20DEN's Avatar
VQ Wizard
You need a 21mm socket to remove the lug nuts and a 19mm socket to remove the calipers. If the rotor doesn't fall out by then you only need to tap it with a rubber mallet.
Old Mar 20, 2004 | 11:57 PM
TEEdotMAX's Avatar
there should be a little hole somewhere in the center part of the rotor. if you can find a bolt that can fit in there perfecly, just crank it through & the bolt will push the rotor off the hub
Old Mar 21, 2004 | 09:17 AM
ZIPPIN's Avatar
Mauja He Mauja
i second that. it's 10 12 0r 14 mm...cant remember
Matt93SE
May 24, 2019 02:58 PM
03VQMAX
Sep 25, 2015 04:19 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
