Tires for 20s
Old Mar 21, 2004 | 12:07 PM
Mack Daddy's Avatar
Tires for 20s
For those who have 20" wheels, what size and brand of tire are you running. I am having a hard time getting one that is the same as my stock. My stock diameter is 641.5 mm or 25.66 inches. 225 35 20 are 26.2 inches which is close enough but only one tire manufaturer that I can find makes them. Nito 555.
A more popular size is 245 35 20 which has a diameter of 26.8 inches. That is more htan 1 inch larger than my diameter. That is like 5% or so larger. Is this too big. I think 2% is better. Are there any other choices out there
thanks
Old Mar 21, 2004 | 12:16 PM
KLOOGY's Avatar
L33t BMW Drivah
245/35 would be the best tire you can put on it. It will provide enough rubber between your wheel and the pavement. Im running 245/35 19's , with no problems at all....
Old Mar 21, 2004 | 12:20 PM
white m3 guy's Avatar
im running 255/35/20 but i want to step down to 245, 255 are to narrow imo
Old Mar 21, 2004 | 05:02 PM
TitaniuMax03's Avatar
Im running 245/35 20's as well..its enough clearance..
Old Mar 21, 2004 | 05:56 PM
Prodigy's Avatar
I have 245/40/19 and I'm rubbing a little, anybody else have this problem or know how to fix it?
Old Mar 21, 2004 | 06:15 PM
you need to do down to 245/35/19 thats whys
Old Mar 21, 2004 | 08:31 PM
limsandy's Avatar
Wait, you're dropped with Progress springs and you still have enough clearance?
~limsandy
Old Mar 21, 2004 | 09:03 PM
yeh you can drop your car with 20's i have maxspeed that are cut one coil so almost as low as teins
Old Mar 22, 2004 | 05:35 AM
Mack Daddy's Avatar
Ok I have just bought H&R springs. Is that ok with that 20" setup?
Also when people talk about rub is it from fender or inside somewhere? At full lock do you guys get any rub?
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
