Stillen RSB for 2k1 Max
Just ordered a Stillen RSB for my 2k1 GXE before noticing previous threads on ABS line issues with Stillen's brackets. Has Stillen made accomodations for this? How did others get around this issue on the 2k1? Thanks.
stillen gave us two metal extension pieces for the ABS lines so the brackets will not pinch the ABS lines...
I put a Stillen RSB on a 2k1 this past weekend. The back RSB braces would not fit properly with the ABS brackets. The ABS line is supported at three points on this bracket. I ended up sawing the center attachment point off of the ABS bracket and with a little touchup paint... After that, everything attached just fine. (Ok, I did need to bend the left brake line support to keep the brake line from rubbing on one of the RSB attachment bolts.)
BTW, anyone had any problems with your friendly garage putting a car lift on the bar?
thatcollegestudent
18
Oct 5, 2015 02:29 PM
Stagnet04
Sep 14, 2015 11:28 PM
