8.798 @82 mph with 35 shot?!?!? (1/8mi)
Went to the track for the first time today with my new setup:
NX wet kit jetted for 35hp
injen intake
cat-back exhaust
UDP
WSPD Y-pipe
Illuminas(set on 3/5)
tein htechs
ES full front bushings
RSB
FSTB
Steelies w/ 205/50-15 Gforce drag radials @18-20psi
Best run:
R/T: .504
60' : 2.115
ET: 8.798
Trap: 81.98
Just wanted to get some feedback ,from some n2o guys who run at the track, on my time considering my setup.
I feel pretty good about it really
. Just wanted to see how my time matches up.
I'll post my slip once I upload it and put it where it's supposed to go in the timeslip forum. Thanks to Plurco, Jime, Nismo, sonic, aaron92se, and others for their shared wisdom and experience.
Oh yeah didn't spray out of the hole, just about 1/2 way through first.
I'll have the video up tonight or tomorrow.
injen intake
cat-back exhaust
UDP
WSPD Y-pipe
tein htechs
RSB
FSTB
Best run:
R/T: .504
60' : 2.115
ET: 8.798
Trap: 81.98
. Just wanted to see how my time matches up.I'll post my slip once I upload it and put it where it's supposed to go in the timeslip forum. Thanks to Plurco, Jime, Nismo, sonic, aaron92se, and others for their shared wisdom and experience.
Good job. I need to get nitrous. I've been talking about it for a long time, but I've been doing other NA mods first. But nitrous is the way to go for a track ***** like me.
That's a pretty good time. I haven't run mine with slicks, and I'm right behind you with a 50 shot dry. I couldn't get off the line any better than 2.228, and my 1/8th time was 9.01@78.94MPH I also wasn't able to hit the juice until I was around 30mph. I would probably be right with you on time with slicks. Good job driving that stick. I'm also auto, so that slows me down a bit from the start with the different launch ability. You're probably on the way to a 13.6 1/4.
Originally Posted by SonicDust187
Did you do a burnout before staged, if not you could have gotten a better time because your tires would hook up better.
Originally Posted by CullenJ76
Thanks again buddy.When I get nitrous, I might try my luck to see how traction is with a 50 shot on these Gforce drag radials. I doubt they will hold while spraying on the launch. But it's worth a try, especially when testing nitrous for the first time. You don't want to go all out with slicks and break something your first time out.
Tires should always be your weakest link... not your axles or tranny.
Originally Posted by Aaron92SE
2.11 is a good 60'. Did you use nitrous in the first 60 feet? If you warm those tires up for only 3 seconds, then they will be plenty warm enough for you to pull a high 2.0 60' on a good night NA.
Tires should always be your weakest link... not your axles or tranny.Jime: thanks
Apr 16, 2020 05:15 AM
