I'm one siked mofo right now....200amp Alternator on the way!!!!!!
I'm one siked **** right now....200amp Alternator on the way!!!!!!
Once again, I'm cooking another alternator.
So this weekend I was on a mission to get an alternator other than our stock Hitachi/Lester/Bosch units. I was almost ready to put a marine alternator in the Max until I found a company down in Tampa, FL named Can-Am Motors. They will make you an alternator along with a mounting kit and harnesses to upgrade to their 200amp alternator.
It cost me $410 and it has a one year warranty. They will also powdercoat it so I went with gunmetal. I can't wait to get my hands on this bish.
Conrad: I'll post pics when I get it.
Gtr: My car was never on the list for the recall so I was getting stiffed with the rebuilt crap. I'm not going to spend another penny on another stock type alternator.
yo, do us a favor, and tell us how tolerable the idle is after you install it. if it's how i understand it, you're gonna have a rough idle. car can't keep such a high current alt. running at low rpm's w/out being rough. higher alt. and it's hard to even keep the car on. that's the only thing holding me back. if you say that it's tolerable enough where you're not bothered, then i'll go along with it, but i'm scared that idle is gonna get annoying.
Wow, that's huge
I was always told that the alternator we have now was the only one that was capable of fitting down there. How much power are you pushing on your system? My 800a4 & bd1000a1 haven't been enough to kill my alternator so it must be pretty freakin' big. Let us know if your lights still blink when you thump it.
Originally Posted by PoLo
did you ever do a current test to see how many amps you were pulling on average?
Idle may need to be adjusted a bit but I can't see losing a lot of power when my car is suffering from an underpowered electrical system. Adding more is better. Plus a high output alternator should come with a smaller pully to ease the load of the belt driving it.
did you pay for your alternator already. Try checking out www.mechman.com for custom high output alternator. I contacted him once to check if he had anything fora 98 Nissan Maxima. He said yes and he also have custom mounts and wiring adaptor so you don't have to cut your factory wiring. It's basically a remove and replace. My friend has one in his truck and it doesn't seem to affect his idle at all.
Originally Posted by BigDogJonx
200amps? That is going to be one hell of a power robber.
How can your alternator not handle your electricals? I am pretty sure I have just as many things running as you(stereo, hids, strobes, s/c) and I have yet to have a problem with my alternator. Oh wait they replaced it over a year ago when the recall alternator almost set my car on fire!
I have a 1 farad cap and my fogs will still dim with heavy bass hits. Who knows if when I had the alternator rebuilt in Providence about 5 months ago if they used new parts. Either way, I'm done with the stock units.
Originally Posted by kingrukus
That is my main concern. I want to go with an HO alternator, but I am afraid that I will sacrifice too much engine power.
Originally Posted by deezo
What did they want to charge you for the whole kit? If I knew all of these shops were around, I would have done this a year ago but the majority of them don't advertise on the web which kind of sucks. It's bad enough going from site to site where nothing is made for Nissan Maximas.
I ended just adding a second battery in the trunk and making my own grounding system like the ones that Hyper ground sells but i only used an 8 ga power wire and soldered the ring terminals on instead of just crimpimg them. And i'm running three amps. And my future upgrade would require me to add another 4 channel amp to it and a few processors. So far no headlights dimming.....
Eric
MardiGrasMax: Weak contact points will cause more resistance/heat to the alternator and wiring. You will never push your equipment to its full potential without opening up the pipeline so that the current will flow properly. On the aftermarket alternator, you'll most likely burn up the wires before the alternator itself.
SprintMax: $410 is the cheapest I've seen and I never talked to anyone at Ohio Generator but I did call them. Even mechman.com want's over $500 for theirs.
Originally Posted by SprintMax
CustomMaxima is an official dealer for Ohio Generator.. they are $5xx .. but i think they put out 500 amps
The company I'm using makes alternators for Stinger and I know a lot of people use them in DB Racing. I can't wait to get this bish so I can look at it, plus, size it up.
It may interest you all to know that the same alternator will fit on all Maximas from '95 - '03. Perhaps even the '04+ and the 3.5 Altima.
I just installed my 3rd one the other day after cooking my 125 amp at the track last weekend.
Originally Posted by mzmtg
FYI, HIDs draw less current than regular bulbs.
Good to know I'm not alone. How long did each one last?
1500 watt stereo, converter, hid, elctronic ign,. i also have the i farad
lightning cap. what type of grounds are you running cause that could cause your problems if your not running at least a four gauge for all the stuff you have. would like to know how it turns out because i heard it also helps your hp a little.
Originally Posted by SamMan23
how would a udp affect all this?
FYI guys.. a high output alternator shouldn't affect your idle-- unless it's designed for high output at lower RPM as well, AND you're using ungodly amounts of power at the same time (sitting in traffic with your system cranked)..
most alternators only output 50-60-80 amps at idle, but when you spin them up to 3-4000rpm they'll put out the 150+ amps they're rated at.
Thus, you won't really FUBAR your idle with a bigger alternator.. plus there's not too many people that can sit at idle and draw 100+ amps of current and NOT **** off everyone within a 1 mile radius of you. to use that much power, the stereo will be cranking 130+dB the entire time, as well as any lights used would be lighting up the sky like NYC. easy way to ask for a ticket.
For those that have huge systems and play at car shows, this is a good option, but even then you're only needing that much power for a minute or two at a time.. you don't sit at shows all day with the system cranked. the battery should be able to handle a few minutes of the system at full volume and then let the alternator recharge it when you turn it down.
(I've got some friends that do SPL comps with 50,000W + stereos, and they have done 50-60 SPL burps without ever starting their cars, and all their results are withint 0.1dB.. no big deal, and a LOT of power draw.)
TallTom
57
Oct 14, 2025 05:16 PM
The Wizard
24
Oct 1, 2015 08:47 PM
