Upgrade fuel injectors?
Does anyone know what the ratio is on the FMU for the 01' Stillen Kit? If I downsize my pulley to add 2-3 psi, do I need to upgrade it, and if so, which one is best? Also, would it be a good idea to upgrade my fuel injectors, if so, what size is best?
Stock 5th gen kits come with 8:1 FMUs. If you are going to say 9psi, then 8:1 will be good.
If you want to go more or want to be safer, then get injectors.
BTW, I have a set of brand new RCengineering 440cc injectors for the 5th gen for sale.
Dixit
Dixit
Cause if you got the SC you got an inline aux pump or you probably did the Walbro 255lph Fuel Pump in the tank. With that you can push close to 90-110psi FP. 100+ FP on the GSS342 Walbro High pressure pumps.
Aftermarket FPR basically helps you adjust the idle fp back to normal after having a high pressure pump installed. The fmu is just that. Boost relative fuel pressure management unit. It raises the fuel pressure X amount for each psi of boost you raise. That "X" amount is based on which disc size you have in or which ratio you have dialed in (if you got an adjustable one like a Cartech).
Dixit
Dixit
Originally Posted by dadiesel
So what size injectors would be best if I wanted to go with 10psi on 8:1 FMU?
If you go larger injectors, the next size up on the 5th gens is the 440cc. These are either the RCengineering or the PE injectors. RC run about 650 new for the set, PE runs in the range of 850-1000 for the set. If you go with 440cc, you probably can run 1:1 at 10psi, I cant be sure about that, need to look at the charts again, but maybe 2:1 or 3:1 may be necessary. But definetely dont need 8:1. Because you dont need to bump up the FP that high anymore with larger injectors which is flowing more fuel at a lower pressure.
Dixit
yeah, ive seen your cartech.
havent reinstalled the aem fpr since i had the leaks, im waiting for my thread sealant to fully dry.
I got the gss342 from pimp juice and its installed.
im just fuzzy on how the fmu actually works.
oh yeah, and what does that screw (bleeder valve?) thats on top of the fmu (vortech)
What part of the boost related fuel pressure increase didnt make sense? As I said, for EACH pound of boost you raise you can raise the Fuel pressure X amount of psi. This can change depending on the disc size or the ratio you choose on the cartech.
As for the top screw, do you have a SFMU from vortech? Because the standard FMU from vortech doesnt have any adjustments except the disc size which physically needs to be changed.
Dixit
Dixit
Dixit
Dixit
did the injectors not work with the e-manage?
i think dixit went bigger.
i know that it adds xx to each lb of boost, but since its after the fpr, i dont exactly know what the physical principle behind it is.
does it put more pressure in the fuel tank?
Originally Posted by HNDA ETR
Nice plug Dixit... verrryy subtle.....
Dixit
Originally Posted by slimer
isnt the gss 342 hp?
Dixit
Steve, GSS342 is the model. They come in standard and HP. So if you asked for just a GSS342, you might not have gotten the HP flow one. This is the tricky part. Some have done this and put it into the tank to find out they got the wrong one.
Dixit
Dixit
jmlee44
Oct 2, 2022 02:13 PM
Forge277
Jun 13, 2016 09:26 PM
