Is this tire size ok?
Old Apr 1, 2004 | 06:56 PM
soundmike's Avatar
Very sound, Mike
Will either one of these two be okay on a 17x8 rim on a 2k2 Max?
235/45
245/45
I want to achieve a couple of things with this change of tires, namely:
- More "padding", i currently run on 225/40/18's
- Better ride
- Hopefully get away from all the bubbles i've been having
- Fill-up the wheel well a bit more
Your help is gladly appreciated.
Thanks.
- Mike
Old Apr 1, 2004 | 07:00 PM
Nealoc187's Avatar
SLOW
Yeah they will both work fine on an 8" wheel.
Old Apr 1, 2004 | 07:52 PM
Ammi's Avatar
350 Detroit Muscle
I would go w/ 235s but 245s will work also
Old Apr 3, 2004 | 09:07 AM
soundmike's Avatar
Very sound, Mike
Would an offset of 35mm on an 8" be good enough to line up the wheel/tire with the fenders or would that be too much? Based on this it looks like the tires would extend an additional 23mm from the OEM 7" at 45mm offset. Is that good?
Ammi, why would you go with 235's more? Is it just because it has a lower profile? Anyway, i'm trying to go for a 245/45/17 if possible just so i'm closer to the oem 225/50/17 in terms of speedo accuracy.
Thanks for the responses guys!
Old Apr 3, 2004 | 11:45 AM
ABS's Avatar
ABS
25.4mm=1 inch
Old Apr 3, 2004 | 01:14 PM
soundmike's Avatar
Very sound, Mike
Thanks, so would that mean - based on the OEM, if i go 8" in size the total extension would be close to 2" outwards towards the fender?
Old Apr 4, 2004 | 08:32 PM
ABS's Avatar
ABS
The answer is that it depends upon the offset of the OEM rim and the aftermarket rim in question. Check in the FAQ for a link to a URL that will help you calculate the offsets.
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
Garrettz459
Sep 28, 2015 02:50 PM
