Is this tire size ok?
Will either one of these two be okay on a 17x8 rim on a 2k2 Max?
235/45
245/45
I want to achieve a couple of things with this change of tires, namely:
- More "padding", i currently run on 225/40/18's
- Better ride
- Hopefully get away from all the bubbles i've been having
- Fill-up the wheel well a bit more
Your help is gladly appreciated.
Thanks.
- Mike
235/45
245/45
- Better ride
Thanks.
- Mike
Would an offset of 35mm on an 8" be good enough to line up the wheel/tire with the fenders or would that be too much? Based on this it looks like the tires would extend an additional 23mm from the OEM 7" at 45mm offset. Is that good?
Ammi, why would you go with 235's more? Is it just because it has a lower profile? Anyway, i'm trying to go for a 245/45/17 if possible just so i'm closer to the oem 225/50/17 in terms of speedo accuracy.
Thanks for the responses guys!
25.4mm=1 inch
Thanks, so would that mean - based on the OEM, if i go 8" in size the total extension would be close to 2" outwards towards the fender?
knight_yyz
Nov 1, 2015 01:34 PM
