how do I fix a broken lug stud?
Old Apr 3, 2004 | 08:33 PM
bvtran's Avatar
94c Big Max
Hey guys, I got a broken lug stud in the rear wheel. The nut is still on there, I couldn't take it off. Any idea how to brake it loose cuz right now I can't remove the wheel. So which means, I can't get to the hub nor the baffle plate. What should I do? A friend of mine mentioned to use a brake bar with a socket and step on that thing until the lug nut broke loose but wouldn't that damage the hub? Any safer way to do it?
Old Apr 4, 2004 | 08:12 PM
Bill G's Avatar
First, how do you know you have a broken stud? Is the lug nut attached, but the stud turns freely? Or are you just unable to turn the lug nut?
It's virtually impossible for you to have a free-spinning stud that prevents the wheel from coming off. I can't imagine this is the case.
If you just have a lug nut that won't turn, then do what your friend suggests. Get a breaker bar and lean on it until the stud breaks. Then replace the stud the normal way. You won't damage the hub. It's made of a much harder steel than the stud, so if the stud does turn a little, it will only damage the stud, which you'll be replacing anyway.
Please elaborate on what your situation is.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
leatherneck
Sep 30, 2015 09:16 PM
