Radar Detector Hard Wired
Old Apr 5, 2004 | 05:51 PM
XMan's Avatar
Hard Wire Radar Detector
I just bought a new radar detector. A Silver Bullet 7500. I want to wired it to the connector that powers the rearview mirror. Anybody has any ideas as to how to do it......appreciate the help. Any recommendations? Do I need to change the fuse ???
X
Old Apr 5, 2004 | 06:17 PM
mailjbrown's Avatar
OK.. I just did this a few days ago on my 04.
You accept full responsibility for your own actions. If you are not familiar with basic electric circuits and splicing wires, GET SOMEONE TO HELP YOU!
1. Open sunglass storage compartment and remove one Phillips screw.
2. Firmly grip the edges of the overhead light/sunroof control assembly amd pull down. You will need to do this very firmly but carefully. The unit is very tightly secured into four self locking clips, but it will come down with persistence.
3. Remove both wiring harness connectors that feed power etc to the interior light and also the sun roof controls. put the light unit aside.
4. Above the mirror is a small telescoping channel against the glass. Pull this down and put aside.
5. Unplug the mirror connector from the back of the mirror. Pull the mirror supply wire and plug back through into the hole where the light was removed from.
6. Using a razor knife of a small pair of pointed nail scissors, carefully cut the outter insulation sleeve for about two inches. Do this close to the head liner (furthest away from the plug end) Inside will be three wires. Black, Orange, and Black with red stripe.
7. Splice your detector wires to the black (negative) and Orange (Positive), and tape insulate each wire completely. Put the splices back into the sleeve, and apply more tape to close the "wound".
8. Feed the mirror wiring back to the mirror, and the detector wire to the detector, following the same original routing. Reinstall the channel, and mount your detector.
9. Reconnect the wiring connectors to the interior light unit. Reinstall the unit by carefully aligning the clips, and reinstall the phillips screw.
10. The fuse will be OK as the detector draws very little power.
Good luck.
Old Apr 6, 2004 | 12:51 PM
Redline's Avatar
I ran mine tucked under the headliner along the roof over to the a-pillar, then under the a-pillar down to the dash and then to a fuse in the fuse panel which comes on with the key.
Old Apr 7, 2004 | 11:47 AM
bigcozz's Avatar
First of all SILVER BULLET? What happened to escort or Valentine. Other than that why hard wire any radar detector that you have to mount in your window i could see if you had detector with bumper mounted sensors and a display you can mount in the window.
Old Apr 7, 2004 | 08:05 PM
lightonthehill's Avatar
XMan - couldn't help but notice you are just a few minutes drive from the Virginia border. Some advice: do not even think of operating a radar detector in Virginia. They are not only against the law there, they are a pet peeve of Old Dominion smokies, who carry devices that detect radar detectors. They consider their use as an attack on them, personally.
Old Apr 8, 2004 | 12:02 PM
XMan's Avatar
Hi Guys...thanks a lot for the help....sure I have some work to do this weekend. Lightonthehill....thanks for the advice...I am going to Virginia on the 25th I will be doing some Autocrossing with my Max....
X
Old Apr 10, 2004 | 01:00 PM
kosd's Avatar
Any chance of you posting a pic of the finished product?
Good luck.
Old Apr 10, 2004 | 02:53 PM
XMan's Avatar
Any ideas how to post a pic?
Old Jul 12, 2004 | 08:15 AM
Viper1's Avatar
mailjbrown,
Thanks for the info. I just installed a Bel 995 radar detector and used a straight
phone cord (RJ-11) for power. After laying a large towel over the dash, I
soldered the wires together. Wrapped the bare wires with electrical tape and
sealed it with a small tie-wrap for good measure.
Viper1
Old Jul 12, 2004 | 10:24 AM
wrj's Avatar
wrj
Redline...how did you get the wire under the a-pillar? My is very tight to the sides.
Old Jul 12, 2004 | 10:57 AM
6thGenMax's Avatar
Curious, why hard wire into the mirror of the max, radars wont work will ontop of the windshield due to the max's small rear window. no rear detection radar would work right, as well as theres some dot matrix stuff which will not work well with the radar.
i just purchased a passport 8500 X50 Blue. with the hardwire kit. i was thinking or running power from behind the (alarm light) in the dash.
has anyone done this before?
or can someone post a picture of where they have it up near the mirror? i cant see any unit working well up there for 360degree's coverage
Old Jul 12, 2004 | 11:36 AM
Viper1's Avatar
6thGenMax,
I have the Radar detector mounted just below the mirror (center of the windshield), it would have the same view through the rear as the rearview mirror. I think if you mount the Radar detector any lower there would be a lot of things in the way.
When I get a chance, I will try to post some pictures.
Viper1
Old Jul 12, 2004 | 12:44 PM
6thGenMax's Avatar
Not doubting that it wouldnt work. i was just never a fan of it being up that high. maybe where you have it is the place to be. i normally put the radar center of the dash up on the windshield about 6-7" up so its not in my way and perfect where i can see it, but yes please take a picture id love to see where everyone puts theres.
Old Nov 6, 2010 | 03:03 PM
SRTuLTR's Avatar
Just did this in my sister's '08! Great find! Thanks for the writeup, I was stumped after realizing that I couldn't pull the A pillar.
Old Nov 6, 2010 | 03:39 PM
Oolatec's Avatar
Give these guys a call... they might have a solution:
http://www.stealthcords.com/shop/home.php
Old Nov 7, 2010 | 04:01 AM
ramberg's Avatar
GrandPa
A 6 year old thread.
Old Nov 8, 2010 | 09:30 AM
Oolatec's Avatar
LOL I know, right? haha
Old Nov 9, 2010 | 05:55 PM
SRTuLTR's Avatar
LOL sorry for the digging this up from the dead, but just needed to throw out a thanks b/c I was stumped at what I was going to do bc of the curtain airbags!
Old Nov 21, 2011 | 08:20 PM
justin2386's Avatar
you can just splice in with the stealth cord? no additional fuses?
Old Nov 25, 2011 | 06:07 PM
moNYtx's Avatar
Would this work if you ran it from the cig lighter?
Old Nov 26, 2011 | 08:04 AM
timpol's Avatar
Just run it from the rear view. You have all the power you need right there.
And no need for a fuse.
I did mine a couple years ago. I probably used the seven year old write-up in this thread!
Old Nov 26, 2011 | 08:28 AM
mrjasonlyrics's Avatar
Isn't these things illegal if caught?
Old Nov 26, 2011 | 09:54 AM
T_Behr904's Avatar
Only in the most **** of government controlled states. I live in the southeast, and the only state i've traveled through that they're not allowed is Virginia, and I believe the D.C. area.
Old Nov 27, 2011 | 05:27 AM
DrewSER's Avatar
All military bases and any commercial vehicles as well.
Old Nov 27, 2011 | 09:18 AM
bryansuavo's Avatar
makes me want to get it, cops over here are ****s.
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
jaydot901
Sep 29, 2015 01:18 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
