Brake Problem: Negligence (Mine)
Hello folks...
Big trouble here: I live in Brazil.. no Nissan parts available.. SO>.. I had this brake fluid leak for almost 1 year.. Just filled the thing up with fluid..every now and then ... and kept going. The leak source was the rear left brake caliper.
Stopped using the car for about 4 months. Last week, I started it up and noticed that the fluid level was intact (full), but.. no brake pressure at all.. The brake pedal now goes all the way down
What else could be broken now ? Already ordered the caliper Kit...
Regards,
BrazilianMax
Regards,
BrazilianMax
it would be your master cylinder or your brake booster...likely the cylinder, but I'd have someone check it out.
Originally Posted by BrazilianMax
Hello folks...
Regards,
BrazilianMax
Regards,
BrazilianMax
okay i just fix my max over the weekend cause it had the same issue. First of all if you are having a leak in the rear it's prolly your caliber. I replaced both Master Cyliner, and rear caliber only to find out. I only need to change replace the caliber.
Hey, thanks BIGHANK. How much did you spend on both? (Master Cyl & Caliper)
Thanks again !
Thanks again !
Thanks again !
Thanks again !
Well i bought the caliper for 175 but , with the core you get 77 bucks back
and The master cyl was 110 with a 40 return. So i paid outta pocket like 168 total.
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
