for those with cefiro headlights.
Old Apr 7, 2004 | 10:36 AM
98I30t's Avatar
couple questions, first, the 10mm bolt that is close to radiator on each side, how did you get to this, looks like to me, I'm gonna have to lean the radiator back, and possibly d/c a couple hoses, second, with the parking light harness, you use the one that came with the light housing? or the stock one, because they both fit into the housing itself, but mixing the stock harness with the cefiro socket looks impossible, any help is much appreciated
Old Apr 7, 2004 | 02:20 PM
98I30t's Avatar
Old Apr 7, 2004 | 03:47 PM
Chunger's Avatar
My other car is a Hybrid
I don't know about the I30s but IIRC... I think the bolts come in from the front of the car... so we had to remove the grill. The I30 grill is part of the hood?
If not, use swivel joints/extensions...
Old Apr 7, 2004 | 05:08 PM
hacim105's Avatar
You might have to shave some of the socket area out to put in the harness.
Old Apr 7, 2004 | 08:07 PM
I30tMikeD's Avatar
You should not have to remove any hoses or move the radiator to get to the bolts, at least I didn't. A couple of them are hard to get to but it's no need to remove anything.
For the parking light, are you refering to the small bulb that is next to the headlight on the cefiro's? That one is calle the "city light" and the stock bulb wont' go in there.
Old Apr 7, 2004 | 08:24 PM
98I30t's Avatar
well I got everything in and working, but it ends up, the drivers side city light doesnt work period, I tested it, and got no light out of anything:/ that and I'm having a problem adjusting the light..they are almost pointing to the ground, and no matter how much, or which way I turn the adjustment, light focus doesnt move..any help is appreciated
Old Apr 7, 2004 | 08:29 PM
I30tMikeD's Avatar
The city light is not a big deal, I don't even use mine. As far as adjustment, if turning the screw does not work I don't know what to do. Is the side to side working?
Old Apr 7, 2004 | 08:45 PM
98I30t's Avatar
Well the elongated phillips screw is what I thought adjusted it, doesnt seem to be doing anything when it is operated, unless the other screw, near the fender in the design of the headlight, adjusts, my headlights are hopeless, light output seems to be quite scattered now anyways:/
Old Apr 8, 2004 | 08:15 AM
Chunger's Avatar
There are 2 adjustment screws... The headlight itself doesn't move (unlike the US models); the reflector assembly inside moves... you will see it as you adjust it. I believe the vertical adjustment one is the outboard ones.
Swap your city light bulbs to see if one of the bulbs is bad. I have mine set so it goes on with the parking lights but goes off when my HIDs go on.
Light pattern with the H4 bulbs should be very good... Are your lights "stamped" with Nissan on the front?!?
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
mpbclutch33
Sep 8, 2015 06:21 PM
99DustMagnet
Jan 1, 2001 04:55 PM
