Unorthadox UDP... The Low Down
After installing my UDP, I didnt notice any gains... My first impression was like WTF... this sucks.
AFter about a week, I guess my ECU went to school and learned the art of the UDP. Wow, my Max hauls *** now. Much quicker acceleration and whatnot. Im also running a good deal of power for my sub... no noticeable drop in power for that either.
Final Analysis:
GO BUY ONE!
Final Analysis:
GO BUY ONE!
i have had the unorthodix racing udp for a long time, i have experienced absolutely nothing negative from it. while i didnt feel any "seat of the pants" gains ..its still going to help and work on concert with other mods "the big picture"
Last year my I was getting 14.4s@98mph with 2.2 60 foots and the UDP. This year without the UDP I'm getting 14.4s@98mph with 2.2 60 foots. I removed the UDP because I didn't like the way it made my car drive and it introduced a little more grainy vibration at all rpms. That's my take.
Dave
Dave
Ive been thinking about getting the motorstorm UDP, becuase its basically same thing, less money, and lighter too! But i dont know if its worth it, cuz some say they felt improvement adn ppl like dave b even SHOWED in 1/4 mile it didnt do anything. So im deciding if its worth it....
does anyone else have comments on UDP? I wanna get this mod, i am just worried that it's a waste of money and might cause problems (even minor). I do know the amp loss, but since i don't have a system i think i should be ok here.
First, thanks for searching!
I don't know what mods you have now, but a UDP would be at the bottom of my list. minimal gains, maybe .05-.1 1/4 mile gain.
search hasn't been working for some time now
Final Analysis:
GO BUY ONE!
Final Analysis:
GO BUY ONE!
enjoy!
Ant
On our car, the crank pulley is NOT a harmonic damper. Nothing to worry about when putting in a lighter, smaller one. Even if the gain is minimal, all mods add up in the big picture.
Dave
This is all very interesting. I never really knew how the UDP really worked. I have seen a lot of people getting it, but I am glad I read up on it some.
It is really hot here, and I know that the air conditioner compressor is hard enough on the alternator at stock amps, let alone at a lower ampage. I don't know if I want to do this or not, esp. if Dave B says that it didn't help him at all in the 1/4 mile.
Originally Posted by Dave B
Lightened flywheels do not affect the crank, but unbalanced pulleys do.
Dave
Dave
You saying that the vibration is dampened with the pulley hence no affect from the lighter flywheel?
Just trying to understand your point of view...
Originally Posted by MadMax95
The flywheel is directly connected to the crank, how would it not affect it?
u guys are tripping. udp will give you performance. it lets ur engine rev up faster because it is lighter and there is less mass to rotate. ur are supposed to use a torque wrench also when tightening it.
As for torque, you need ~90 ft/lbs and then an additional 1/8th turn I believe. This results in a torque value of close to 140-150ft/lbs.
Dave
Im with Dave....I have been getting a vibration threw my car ever since that thing was put on...I feel it mostly at low RPM's, say about 2500 in 4th or 5th...Im having it taken off on Wed and Ill sell it with the belts
-matt
-matt
Dave....question...
What about the UR Street Charger Crank Pulley? Stock diameter, yet still lighter than stock. Would this be a better option than the smaller UR UDP? Would this help dissapate engine vibrations and in turn help the engine/drivetrain perform better?
Originally Posted by sbslacker
Dave....question...
Dave
Hmm. at 89k my serp belts are getting a little old and I was going to replace them. I was considering the addition of a UDP at the same time, because I would need new belts anyways. This sort of 'puts the icing on the cake' for UDP's IMO.. I would rather stay with stock pulley for a couple of reasons now:
1. Aftermarket parts are notoriously bad, in comparison to OEM parts, especially those that are directly connected to the drivetrain.
2. With A/C, P/S, and a High current amp capable of 1200watts, a UDP would result in too much additional strain on the alternator.
So what's the best place to by stocksize belts, (if I am replacing all of them) and who's got the best write up on replacing them?
Input is appreciated!
-Kevin
-Kevin
well...I don't know who to believe on this topic...seems to be everyone's personal opinion...so I will give mine...I have had mine installed for about 8,000 miles with absolutely no problems, no valvetrain problems, engine problems...nothing! I did not notice much of a gain, but it was there...IMHO it's not worth $190 from unorthodox...if it was cheaper it would be a better deal
well think about it. a udp works as a damper but not that big of a damper.a reason u could feel vibrations in your car is ur engine mounts coulbe be bad and when driving if you feel a vibration, you tires could not be properly balanced. thats is my 2 cents.
Even [B]if[B/] a lightend/smaller diameter UDP proved to cause no ill side effects the power gains from it are not worth it. There are many more performance mods to spend money than a UDP.
litch
123
Jan 4, 2024 07:01 PM
