Question about in cabin air filter....
If you have an 02/03 your incabin filter are reusable. You can clean them with
with water just like the K&N filter. I've done mine twice already. Saves you many
$$$$. Good luck
Mike
$$$$. Good luck
Mike
Originally Posted by MAXRN
can you clean out the original cabin air filter? thx.
INSTALLATION INSTRUCTIONS FOR MAXIMA INCABIN MICROFILTER
http://www.courtesyparts.com/instruc...binfilter.html
$$$$. Good luck
Mike
$$$$. Good luck
Mike
I'm not using any oil on it. The manual doesn't calls for it. Just put the filter
under a lukewarm tap water (no soap) from cleanside out and let it air dry.
That's all you need to do. Just make sure you don't use a waterhose or
an air compressor to dry it. Or else you'll just damage the filter. Enjoy!!!!
Mike
Mike
Originally Posted by Triple8Sol
So are you using the actualy K&N filter cleaner and then reoiling it too? Or do you just soak it in some soapy water?
It's drying in the sun now. The stock piece is pretty cheesy. I think I may have to replace this thing eventually, since you can't really get the black/grey dirt off...
I agree... I replaced my last year. You have to pay $$$ for the good one (check Courtesy Nissan site) but I think it is worth it. And you probably don't have to replace it every year (or 15k miles) as suggested. I will be checking/replacing it every two years.
Originally Posted by xXx TeCaO xXx
what he said.........
Peace.
the stock filter is junk, i work for a dealer, the replacement from nissan is awesome and it does look gray out of the box, but it does still have to be changed at the same interval, i've never had luck cleaning them...
Originally Posted by irish44j
the "black/gray" is how it's supposed to look. When I got new filter cartridges from Nissan they came out of the box looking kind of gray....are they charcoal-impregnated?
I think they have charcoal in them... odor absorber...
lux97Max
Sep 4, 2015 05:42 PM
sdotcarter
Sep 2, 2015 09:53 PM
