EGR cleaning service?
Old Apr 20, 2004 | 10:05 AM
knight71's Avatar
Has anyone here ever had this done on their max...I pulled code 03/02 (egr..hi/lo
flow)...it was suggested to me that carbon buildup has blocked EGR passage and has to be cleaned out..Any ideas how much it would cost?
Old Apr 20, 2004 | 10:10 AM
Mizeree_X's Avatar
Getting back to his roots
Do it yourself. Here is a writeup for the 3rd gen: http://www.geocities.com/cbmaxima/maxima/egr/egr.html (thanks to Craig). It may be more dificult to remove the 4th gen EGR, but other than that the instructions should be the same. I did it and it took 15 minutes. Obviously, the new gasket part # is different for a 4th gen. Hope that helps.
Old Apr 20, 2004 | 12:53 PM
Ceasars Chariot's Avatar
Old Maxima Legend
any noticable increase in performance ?
Old Apr 20, 2004 | 01:21 PM
krismax's Avatar
Father of the 00 VI
For me yes, its not hard to take both of them off.
I weigh 250lbs and got it off ,just put my chest on the IM and reached behind with a crows foot.
The small tube was 70% blocked i acid dipped it and sandblasted them out. All stumbling went away and hesitations.
Old Apr 20, 2004 | 01:23 PM
Old Maxima Legend
my egr is clogged or shall i say PLUGGED but the mechanic told me i would lose HP if i cleaned it out, so i have been trying to figure out what to do ?
Old Apr 20, 2004 | 02:33 PM
Mizeree_X's Avatar
I noticed absolutely no difference between a busted EGR and a working one. The only way I knew it wasn't working is because I failed NOx twice.
Old Apr 22, 2004 | 07:24 AM
Tort's Avatar
I was going to clean mine a couple days ago and I took the whole Intake assembly off and tried to disconnect the egr tubes but I could barely see them nevermind get a wrench in there. Did you have to take your intake manifold off to do this? If not how did you get the tube off?
Old Apr 22, 2004 | 11:38 AM
krismax's Avatar
Father of the 00 VI
Just like I said in my first post put your chest on the Intake manifold ,knees should be on the radiater. Lay rite on top of the engine.
No the Intake manifold stayed on but I had the intake system off along with the TB and IACV body.
Old Apr 22, 2004 | 09:24 PM
Lonely Driver's Avatar
In theory, the egr only works at cruise or light acceleration. When you floor it, it will not have any negative effects.
my03maxima
Jul 28, 2024 07:40 AM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
fx4five
Oct 1, 2015 04:58 AM
