Slicks
Old May 10, 2004 | 06:14 AM
MaxSpeedSE's Avatar
Slicks
Anyone have any experience with slicks? I want to put a pair on the 15-inch saw blades, because im rolling on a pair of 17s. I hear things like I need to be careful witch kind and size I get because it will change my gear ratios? Can I get some help? I own a 96 max, 5 speed, with Intake, Y pipe, cat back, and 100 shot.
-Chris
Old May 10, 2004 | 07:11 AM
SonicDust187's Avatar
Dont use sawblades. Use the millenia wheels. I think they are lighter. I think you may need small slicks like a 23-24". But what do I know, talk to guys that can run simulations. Like neal.
Old May 10, 2004 | 01:37 PM
ajsince81's Avatar
when did up to a 100!
Old May 10, 2004 | 05:17 PM
MaxSpeedSE's Avatar
Sonic im not worried about weight...i want them for my 15 inch rims
Ajs, like the day after i got off the phone with you
-Chris
Old May 10, 2004 | 05:29 PM
Jime told me 24" should be good.
Old May 12, 2004 | 12:27 PM
plurco's Avatar
I ran sawblades with 24" RM slicks and a 75 shot. It was good enough to net me a 13.1@105
Old May 12, 2004 | 12:42 PM
MaxSpeedSE's Avatar
How well did they hold plurco, would they be able to take more like the 100 shot? what does everyone mean when they say 24" i dont see thoes specs when i shop for them online or summit mags, i see 3 numbers....
-Chris
Old May 13, 2004 | 03:10 PM
red99ls1ta's Avatar
-Chris
24 " means that the tire is 24 inches tall. if youre going to put them on a 15 inch wheel, you should look for a 225/60/15 or so. the middle number is the amount of sidewall the tire has. the more sidewall, the more flex meaning more traction. since you are fwd, you really dont need to worry about that. id go with a fairly small sized tire up front.
Old May 14, 2004 | 06:39 AM
MaxSpeedSE's Avatar
so when they say 24" what would mean somthing like 24 x 5.0 - 15 ?
Old May 14, 2004 | 07:30 AM
Jime's Avatar
Slicks are not sized like normal tires. The usual measurements are like 22x8x15 which is the height, tread width and rim size.
If you get into drag radial or cheater slicks then that is a different thing altogether.
Check these out.
http://www.mickeythompsontires.com/strip.html
http://www.intercotire.com/html/drag-slicks.htm
Old May 15, 2004 | 01:09 PM
Tally Max's Avatar
Check these out.
what kind of wheels did you put your slicks on for your 02?
Old May 15, 2004 | 01:35 PM
Jime's Avatar
Everything I used is from my 95, the wheels are Kosei K1 7x15's which I bought used for $150. The only real extra stuff I had to buy were the exhaust and Illumina's.
Maxima_Joe
Nov 25, 2015 08:19 AM
Xi MaX SC
1/4 and 1/8 Mile Racing
Aug 7, 2015 08:47 AM
MardiGrasMax
Dec 3, 2001 07:27 PM
