** 2X 12" Subs w/ Bose HU! PICTURES / Semi-Write up **
OK orgy members!
I've got my some pics (despite poor quality) cuz everyone said they wanted some.
As well to answer some questions that people were asking.
Plus a mini-write up of what I did.
Q/A:
1) Reason I chose to hook-up Amps/Subs to the stock HU is because my love affair with my Maxima is ending soon, gonna trade her in in August, so I don't wanna spend money on a HU (yet, till I get my next car) or bother taking the dash apart.
2) EVERYTHING in my car right now is 'experimental', a learning process for me, the subs are temporary, going to be selling BOTH of them, the Amp (crappy) I'm using right now isn't mine. I have a "Rockford Fosgate Punch P6001" coming the end of this week.
3) This is my first attempt at car audio so I wanted to try / learn different things.
4) Sound quality is acceptable, I get 200% more bass than the stock setup, but the rear deck / truck vibrates like a ****.
5) Overall setup took about 2 hours in TOTAL!
6) L.O.C. Cost $15, Stinger 8 Gage Wiring Kit Cost $40 (Best Buy employee price), Stinger Power Cable Splitter ($6 BB employee price)
Now for Pics:
MTX Thunder 9000 Series 12" (Discontinued), Pioneer TS-W305C 12", Jensen 500Watt 2/1 Channel AMP, Alpine V12 Series 300Watt 2/1 AMP (Discontinued)
Half My Trunk is Used up!
InstallEdge (Rockford) Adjustable LOC (Line Output Converter)
Wiring Writeup is Next
Q/A:
Now for Pics:
Write Up
I used:
Stinger 8 Gage Complete Wiring Kit (Pick your own weapon of choice)
Hardest part is running the power wire, after a few suggestions from various members, I decided to run the wire via the Trunk Release Wire grommet. Just follow the wire, you can't miss it.
Removing the Driver side fender liner will help 300%! Its held on by about 4 bolts / rivets.
Hiding the wire is pretty simple, just pull on the plastic pieces that connect the door / carpet (hard to explain but I'm sure you get the idea) they just snap off easily. Hide the wire in there.
Wiring LOC:
7X 18-22 Gage QuickTaps will make your life 100% easier.
I bought the LOC (Line Output Converter) *pic is above* at BestBuy for $15.
Remove harness /plug from Bose Amp located on the rear deck in your trunk (can't miss it, only one plug going into stock Bose Amp) remove a large amout of Electrical tape to access the wires.
Wires to Tap: (I tapped the Input wires to the Rear speakers)
Left Speaker Wires -
Left Positive (+) is BROWN / Left Negative (-) is BLACK & RED
Right Speaker Wires -
Right Positive (+) is LIME GREEN / Right Negative (-) is BLACK & WHITE
Tap those wires with your Quick Taps to the appropriate wires on your LOC.
AMP On/Off Signal (a terminal on your Amp):
I tapped the GREEN & WHITE wire on the Bose Harness / Plug.
Wiring LOC:
This is the way I was going to do it but I heard there was a boominess to the sound you couldnt remove because you were using signal from the BOSE amps. But If you say it sounds good then Im going to give it a whirl.
ahh see now using the signal from the HU is a much better idea. What do you have the dials set to on the LOC? I was thinking that since the HU sends out preamp signal already then you could just skip the LOC and use regular RCA cables spliced into the HU preamp wires.
bigfrank
Oct 1, 2015 12:51 PM
