What causes the squeaking, chirping noise?
Old May 20, 2004 | 05:24 PM
WordUp's Avatar
How's it hang'n fellas....well I've got an auto 2000 SE and whenever I go over mild bumps, rough roads, or just closing my doors I hear this high pitch, squeak, chirping noise. I really can't pin point it but it seems it's from the inside/outside front of the car on both sides. On some occasions I won't hear a thing...weird. I do have a tower brace...but i've tried wiggl'n it, and nothing. Well thanks for any info...Wordup
Old May 20, 2004 | 06:34 PM
Max_Vader_2K's Avatar
I hear the same thing on my car. I go in for a break job tomorrow. hopeing that I find that sound. Got 89K miles on the car. could b old age.
Old May 20, 2004 | 08:38 PM
Mick Max's Avatar
Wild at Hurt
A lot of rubber suspension bushings in these cars and they can dry out. Get a couple of cans of silicone spray and spray the crap all over any part that has movement during suspension.
It has worked for me on other cars and if it does not work you are only out $8 and 20 minutes of your time
Old May 21, 2004 | 02:42 AM
MaxxSpd2k1's Avatar
This topic was brought up before i think someone said that the springs might be going bad..
Old May 21, 2004 | 05:54 AM
ihavea5spd's Avatar
spray a little lubricant on your hood latch.
that is probably the problem.
Old May 21, 2004 | 06:02 AM
PhillyFanCS's Avatar
I have the same problem with my 2000 SE. This has been brought up before with no real answers although the suggestion of spraying silicone mentioned in this thread sounds like it is worth trying.
Old May 21, 2004 | 06:20 AM
ihavea5spd's Avatar
trust me guys. it's the hod latch. if it was your suspension, you wouldn't here it when you close your doors. it's the hood latch.
Old May 26, 2004 | 04:36 PM
BLCKMAX's Avatar
bump 000000000
Old May 26, 2004 | 04:58 PM
MaxxSpd2k1's Avatar
Yeah he has a very good poin cuz when i go and push down on the rear shocks i dot hear anything and on the front ones 2 but when i shut my door i hear it.. So i should just put some silicone spray on it???
Old May 27, 2004 | 11:12 AM
ihavea5spd's Avatar
you can just spray some wd 40 on it, or you could even dab some motor oil on it. anything to lube it up. get the U shaped latch on the bottom side of the hood and the latching mechanism itself.
i had the same problem. if it was a squeak, i'd say look to your suspension. but the "chirp" gives it away. good luck.
Old May 27, 2004 | 12:22 PM
takkar's Avatar
I was getting a creaking noise from the front suspension..got tired one day...bought a can of WD40 and emptied it by spraying it all over the suspension parts ( moving and those in contact)...one year has gone by and no noise so far
Old May 27, 2004 | 12:48 PM
NewLoveI30's Avatar
He's right! I did this when I first got my car. Quick easy fix.
Old Jun 7, 2004 | 08:05 PM
BLCKMAX's Avatar
what happens if the sound is coming from your rear?
Old Jun 7, 2004 | 08:23 PM
PearlWhtMaX2000's Avatar
i had this problem also, just put some lube on the hood latch, thats all it really is
Old Jun 8, 2004 | 06:26 AM
ihavea5spd's Avatar
then it's probably not the hood latch.
Old Jun 8, 2004 | 07:07 AM
stevay's Avatar
i have this same sound also and it aggrivates the **** out of me...i will have to try that remedy.
Old Jun 8, 2004 | 08:36 AM
NewLoveI30's Avatar
Chech for Gerbals!!! LOL!!! Gerbals!.......
Sorry, I couldn't help it. Dont take it personally.
Old Jun 9, 2004 | 08:05 PM
BLCKMAX's Avatar
GERBALS??? Please do explain
Old Jun 10, 2004 | 10:38 AM
2000GXEinGA's Avatar
I have a similar noise coming from the left rear wheel/brake/spring area. It only started after I put on aftermarket brakes pads and rotors. I'm going to try the lubrication on the suspension parts, but am unsure about where to spray. Any pointers?? Car's on the lift as we speak, so quick responses would be very much appreciated.
Old Jun 12, 2004 | 12:04 PM
BLCKMAX's Avatar
I am hoping to change my boots and shocks/struts maybe that will solve it.... will keep you posted
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
