To people with purge kits
Old May 24, 2004 | 09:41 AM
euromaxima's Avatar
When you purge do you see the vapor really well. When I purge i can't see any vapor, you can feel it but can't see it. I have 2 2lb bottles. is that my problem? thanks
Brandon
Old May 24, 2004 | 09:43 AM
96 N/A Max's Avatar
u have 2 2lb bottles? does that even do anything for you when i purge it shoots white gas out
Old May 24, 2004 | 09:51 AM
euromaxima's Avatar
when i first got them filled it shot out gas but they still have quite a bit in there i took it off when i got the car painted now i cant see anything but you can feel it. when i open the bottle you can hear it go in the lines.
Old May 24, 2004 | 10:26 AM
SonicDust187's Avatar
your empty man.
Old May 24, 2004 | 10:44 AM
skandalouz's Avatar
if u cant see white smoke shoot out... ur runnin very low.... and i suggest u get a bigger tank than the 2 2lb ones....
Old May 24, 2004 | 10:54 AM
You may also be low on pressure, raise it some.
Old May 24, 2004 | 11:09 AM
euromaxima's Avatar
how do you raise the pressure? i guess i need to refil it.
Old May 24, 2004 | 11:15 AM
Sinse its summer time the bottle should be close to 900psi as is. Try to refill it first, then get a bottle heater, if you cant, try sticking the bottle into hot water, worked for my buddies NOS system.
Old May 24, 2004 | 11:42 AM
euromaxima's Avatar
when i purge my lines for the purge freeze so I didn't think i was really low.
Old May 24, 2004 | 11:51 AM
First thing you should do is get rid of those 2 2lb bottles and either get one 10lb one or 2 5lb ones. Then get a pressure gauge for the bottle(s). After that a heater is a must, and if possible a bottle blanket. I currently dont have a blanket but since I have a heater im not too worried.
Old May 24, 2004 | 08:07 PM
elchino's Avatar
I've noticed that depending on the weather you may or may not see a big plume of nitrous. (Most of the time you will see some white gas though)
Old May 25, 2004 | 03:55 AM
Yea, the warmer the weather the nicer the purge. But I compared a NOS purge vs my NX purge and with NOS I could only hear, with my purge I made it run home with its tail between its legs. DaThrillir will testify.
Old May 25, 2004 | 09:18 PM
Nismo's Avatar
how are the bottles positioned maybe the pick up tube isnt getting any liquid.
litch
123
Jan 4, 2024 07:01 PM
tseng1023
Oct 15, 2015 08:30 AM
BobTX10
Oct 7, 2015 08:43 AM
Pied
Sep 26, 2015 03:29 PM
