To people with purge kits
When you purge do you see the vapor really well. When I purge i can't see any vapor, you can feel it but can't see it. I have 2 2lb bottles. is that my problem? thanks
Brandon
Brandon
Originally Posted by 96 N/A Max
u have 2 2lb bottles? does that even do anything for you when i purge it shoots white gas out
Sinse its summer time the bottle should be close to 900psi as is. Try to refill it first, then get a bottle heater, if you cant, try sticking the bottle into hot water, worked for my buddies NOS system.
First thing you should do is get rid of those 2 2lb bottles and either get one 10lb one or 2 5lb ones. Then get a pressure gauge for the bottle(s). After that a heater is a must, and if possible a bottle blanket. I currently dont have a blanket but since I have a heater im not too worried.
Yea, the warmer the weather the nicer the purge. But I compared a NOS purge vs my NX purge and with NOS I could only hear, with my purge I made it run home with its tail between its legs.
DaThrillir will testify.
litch
123
Jan 4, 2024 07:01 PM
tseng1023
Oct 15, 2015 08:30 AM
Pied
Sep 26, 2015 03:29 PM
