safcII settings?
safcII settings?
is anyone running a safcII on there N/A fourth gen? If so could you give me some ideas of what settings I can use. I am not trying to maximize my power right now but I would like my car to run safe until I can get to the dyno....thanks.
Carson
**I have CAI/Exhaust/and Y if this makes any difference
Carson
Carson
Carson
I did manage to pick up a bit at the track N/A with the wideband and S-AFC but its minimal, but I do believe its worth knowing that the A/F is flat across the board.
Originally Posted by Jime
If you are running N/A it will be safe, believe me.
Do you have any suggestions to where I should have it set? I have it set for 6 cylinder, arrow up....hot wire 4 in 4 out...low throttle 35% high throttle 65% 01,01 on the MAF. I have played with another screen to set up something else with the throttle....but I was just hoping some one could recomend some safe base settings. Thanks.
I wouldn't change any of the high throttle settings until you hook up to a wideband, otherwise you are just guessing.
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
