Breaking Idler Pulley Center Nut
I was struggling all this morning trying to break the center nut for the idler pulley using a wrench because I couldn't seem to fit a breaker bar into the 1" gap. Sprayed a little WD-40, but that didn't seem to work. Somebody has to have had similar problems. How'd you guys loosen it? Also, I was using a 9/16 wrench(obviously not the best idea) because I don't have a metric wrench set, what metric size is that center nut?
The size of the nut is 14mm. Definately get a metric wrench set(at least) if you want to keep working on your Max. Try using PB Blater or Liquid Wrench to get it loose. You can also hook another wrench onto the end of the one your using to get some more leverage. Takes a little experimenting to get it right.
Its amazing what having the right tool can do towards making a job easier eh? glad you got it sorted out...
Out of curiousity - what the heck do you guys mean by connecting metric wrenches end-to-end... I don't see how you are going to be able to connect them well enough to get any leverage...
I get ya... although you are right.. a picture would be useful... maybe I'll put one up tonight when I get home... wouldn't it be easier to just get a $5 black pipe 3ft length from your local HW store and use that around a rachet... thats how I broke the 17mm bolt on my starter loose..
knight_yyz
Nov 1, 2015 01:34 PM
