Mechanics / Techs / Experts Please Help!!!
Old Mar 28, 2001 | 12:11 PM
MaineI30's Avatar
I just got a call from the dealer about my issue. (see: http://forums.maxima.org/showthread.php?threadid=30493)
He says someone messed with the ECM harness that sits below the center console (to the left of your leg if you're sitting in the passenger seat). He said that they took the cover off the ECM harness, tapped a wire with a new wire, then cut that wire. They claim it might be due to this that my engine is doing that !!! (loose wire to ECM or something.. he says it's all wired together back to the engine...) I think it's ridiculous for these reasons:
1. They are unable to replicate the problem by messing with the harness or pulling on wires, etc.;
2. It was done a LONG time ago and the problem has only happened in the last month;
Anyway they took a photo and will show it to me. They say it is $1750 to fix it and that they can't even guarantee it will fix the problem.
Now they want $150 for their 2 hours labor in checking my car.
Any ideas where to get a second opinion near Boston?
Someone help!!!
Stressed out bad,
/aac
Old Mar 28, 2001 | 01:52 PM
1MAX2NV's Avatar
Who else worked on your car? Alarm guy? sound system guy?
Someone help!!!
Stressed out bad,
/aac
Old Mar 28, 2001 | 01:56 PM
MaineI30's Avatar
Sound system guy and I also have. But no way did I hack into a harness. All they are saying is that someone took the COVER off the harness, tapped a wire into another wire, but they then taped off the wire that they tapped (so it's not attached to anything). They cannot replicate the problem by messing with the harness area, either, so I'm doubtful they are on the right track.
Also, the stereo work was done at about 9,000 miles and the car was 100% fine until about a month ago (30,000 miles.) They want to do this $1900 repair but they say "they really can't guarantee it's the problem, but if it were my car I'd want this fixed..."
I would like to talk to a TRUE Nissan/Infiniti engineer and get their input.
more thoughts please before I have a nervous breakdown..
/aac
Old Mar 28, 2001 | 09:00 PM
MaineI30's Avatar
also
i might just contact a guy i know at Infiniti Consumer Affairs tomorrow and see if he'll let me talk to an engineer out there...
/aac
Old Mar 28, 2001 | 09:37 PM
Stillnmax's Avatar
anthony, if it is electrically related maybe the wireless ethernet connection to your comp might be doing it. Maybe a shielded wire has become unshielded and frequency disturbance might be the unresolved factor.
Just a thought. Sorry to hear this bro....
Old Mar 28, 2001 | 09:41 PM
MaineI30's Avatar
Thanks for the input. The computer has been out of the car for the last few weeks, so that's not the issue.
I've thought of some additional points I'm making with the dealer tomorrow:
1. Stereo work was done at 9,000 miles – car has been fine until 1 month ago at 30,000 miles
2. They claim a wire was tapped from, but left intact in the harness, and the wire leads nowhere (it's taped off). How can this possibly affect ECM and generate these exact codes and behavior?
3. The ECM is not behaving erratically – it has produced the same error codes twice, both times when this issue came up:
IGNITION SIGNAL – PRIMARY
CYL 2 MISFIRE
(plus, wouldn’t you get an ECM error code if the ECM was having signal trouble??)
4. The dealer says they are not positive it’s the problem but "i'd fix it if it were my car."
5. Dealer cannot replicate the problem by messing with the harness area they are blaming
thanks for any and all additional input. I really appreciate it guys, this is really stressing me out.
/aac
Old Mar 29, 2001 | 07:28 AM
CKNY's Avatar
Thats such bullsh!t. if it was the wire then it would have happened after the install, not 21k miles later. And if I'm paying clsoe to $2k they BETTER guarantee it'll fix my car and maybe even hook me up with some stripper or something.
Where'd you take it? your dealer? Take it somewhere else, preferably an independant shop you or someone trust. Ask around.
Chris
Old Mar 29, 2001 | 07:52 AM
MaineI30's Avatar
Chris
Yeh and it better be a lot more than a lap dance!!!
I took it to my dealer. I am going to get a second opinion. Maybe a third. I thought about taking it to another Infiniti dealer closer to Boston. A good independent shop is also a good idea. Thanks for the input man.. I'm going to get my car/talk with the dealer this morning.
/aac
Old Mar 29, 2001 | 08:22 AM
sleeper's Avatar
taped wire
to install air/fuel gauge you have to tap a wire in the harness. 2nd row down 7 or 8 across, something like that. what was the problem? a miss. if so might be a bad coil pack,
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
