Someone help me my car went crazy
I got a 93 gxe,
today I pushed down the back driver side window(the motor doesnt work) and the the damn horn started honking over and over wouldnt stop until i pulled the battery terminal. after a few minutes I connected the battery back and tried cranking the engine... nothing and then it started honking again.. next to my + batter terminal it had 2 plugs I unpluged those 2 and pluged them back in and the car started but the wipers went nuts going fast as hell until they broke.. but nowi disconnected one of the 2 plugs and it works.. fine car cranks on but the driver doors window controls and seat belt wont work... :| heh any ideas?
sound slike an alarm issue since maximas comewith those cheezy stock alarms next time it does it put your key in the drivers door and turn it and see if it stops i am wondering about this too. that is how you de arm the stock alarm that may have somethign to do with your problem
yeah... i do.... After my max was broken into the alarm went haywire. NIssan dealership says the fix is about $500. THe two plugs on the terminal are connected to the 1. ecu 2. alarm/ all other electricals. THe one closest to you would be the alarm /ecu. by cutting away the plastic which holds them together you should be able to pull one out at a time. BEWARE. This is only a temp. fix. Pull out the alarm/etc plug and start the car, then plug it back in and you should be able to hear the electricals turn on inside your car. Whenever you turn your car off again. youll have to repeat the procedure. P.S. if you stall the 5-spd, ull be stuck in traffic running out to open the hood and pull the wires every time!
:\ I think I just gave the car it's last moments in life... smoke started coming out of the vents by the windshield over on the passanger side I... think I killed the poor thing now.. of well time for a new car :|
wow, uh, that sucks...
anyway i have a "psycho" alarm, it only goes psycho sometimes though (about 5% of the time i try to get into my car id say). this may not have any hope of helping you now (wtf did you do to your car exactly?), but for anyone else with the psycho alarm the only way for me to shut it off when its going crazy is by opening the TRUNK with the key. opening any of the doors wont stop it for me. dunno if i have the same problem as anyone else though
Do your front floor mats ever get wet after a hard rain you may have a leak somewhere and something got wet and started the problem. But if smoke started coming out that means something deff. fried you may need to re-wire find out what melted and go get new wire/plugs from the yard.
i mean plugs and wire harnesses for under the dash not spark plug wires, Well my floor used to get wet all the time till i fixed the front cowl where the wipers mount and i had a similer problem and had to run all kinds of new wires but never had anything melt just lost my cruise control, turn signals, highbeams, and dashlights, this happened a day or so after it poored for like 6 hrs and the crusie control unit was soaked! Just an idea
ya I know what you meant.. it's just.. to much work.. I dont think I want to put that kind of money and time into that car.. mainly the time.. I think I damaged too much.. Im going to check it out but I think the cars history
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
JMag90
Aug 25, 2015 09:17 AM
