How Can I Get the Best Engine Performance on a '93 Maxima GXE?
What cheap modifications can I make to my '93 Maxima GXE to increase the engine performance considerably? Also, I've seen some suspension kits for a '93 Maxima 'round the internet, what would you recommend?
what about eibach?
Before you start any "mods", start doing preventable maintenance. Fix/ replace any problems you have or any parts that are prone to fail if you have relatively high miles and most of the parts are original. I assume you've got your timing belt. water pump, tensioner taken care of...suspension and steering components are in good condition...etc. If you have an original tranny
= high miles, start saving for a rebuild. No use forking out all your cash for mods and then having basic maintenance issues later. I speak from previous experience.
oh, well maybe we should re-invent the sticky, with a full list stuff, from simplest to hardest???? Just a thought, like list starting with pop charger and ending with full engine rebuild. just a thought.
Okay, thanks guys. I'll consider replacing some old parts before I do anything!
Anyway, we're getting the alternator replaced Monday, and I plan on replacing the brakes/rotors/calipers etc. What b/r/c parts do you recommend for my 3rd gen. GXE?
Warspeed, you can even do the hybrid approach which is to use a 90-93 Accord's CAI. It will be a HAI for the VG but it is an intake. You can get it from ebay. Look for the Bomz CAI for the 90-93 Accord.
ahh crap. drums.
with the rear disc conversion part. I even have the rear disc suspension setup if you want it
Freaking heavy though. Together with internetautomar, we could make this dream a reality! *insert chords of angels here* aaaa...men....
swap in a rear disc setup!
BTW
I sell the new parts you'll need for the brakes
BTW
Hey! Drums rock! We never have to wash our rear wheels because of brake dust! So what if our cars don't stop. At least they are clean!
edit - it's kind of a big project to convert to disc. You need to remove the rear struts and replace them with SE struts... So you're gonna need spring compressors and everything. There is a link to a writeup somewhere, I forget where but I'm sure somebody will give you the link.
Well, It seems that it would be easier to have an SE and install the GXE luxuries than to have a GXE and install SE performance... Oh well, the rear disc brakes look like a good idea, they do come stock on the SE right?
Actually it would be quite a bit harder to install the GXE goodies. ie.. touch keypads, auto climate controls, electric suspension etc...
Look at what the GXE has that the SE doesn't. Then think about how difficult transfering those systems over to the se.
SE performance? I assume an VG powered se. It's just springs/struts/swaybar. Even the rear disc swap is cake compared to transfering the keypad over.
It depends on what all you're doing... anyway, I have a gxe, and I plan on giving it se performance...
Yeah, the keypad would be the hardest definitely. But anyway, my main goals are to replace my dashboard(it's got holes in it), and make it perform like the SE although it's not. Also, I plan to change the gauges, but it's not that important.
Well, first I'm planning on installing a hybrid Accord CAI, then I'll be replacing the rear drum brakes with disc brakes(hopefully if I get the money). I'll do other stuff when the time comes. As for the disc brakes, I'll probably be using Axxis Brake Pads for front & rear, and Brembo Replacement Rotors for front & rear also.
Gxse now that is what i'm talking about.
Rear disc and break lines, motor swap, suspension upgrade( shocks, springs, Sway bars), it can be done, oh yess it can be done. all i would like to know is what makes an R model. GXSER ya
Originally Posted by lophix
...because you have abs.
I have a 94 GXE without ABS and i have 4 wheel disks.
EDIT: But then again the vin number on my car doesent work in any shop computer, and i had a suposed calif only trouble code.
It would be cool to see pics of your engine bay and rear discs. Maybe someone coverted it?
Nope, my family has had the car scince new. My grandfather bought it in 94 in victoria BC, then when he lost his liscence for hitting a pedestrian (he had no depth peception). He gave the car to my mother, who drove it across the country to ontario (where it is now) in 1999 where my mom drove it until i got my liscence and now its mine.
I sec on the pics and ill load up what i have (i dont have any rear disk pics but i do have engine bay ones) The rear disk pics will have to wait until my brother gets home with my car.
dash1
dash 2
Car 1
Car 2
engine bay1
Its really dirty in those pics, its a lot cleaner now but yeah the pics of the rear disks will have to wait until 3.
Canadian is the only part you needed to mention.
All Canada spec 3rd gen Maximas have discs in the back, and I believe they don't have the stupid power seatbelts either. they also have emissions stuff a little more stringent than the regular US-spec maximas, so you might indeed have a problem with the codes.
how much?
Is there a website?
Is there a website?
Website, www.internetautomart.com
Brians account is currently not working because he tried to switch emails and the org is messed up, so he asked me to reply for him.
You can also send him an email at sales@internetautomart.com
