Lowered Car, Still Having Problems, tried all advise so far. HELP.
Ok, I still need your guys help in this one!
I lowered my 130T 2001 a few weeks ago. I used the H&R spring kit. It was to work fine with stock shocks on a 01 SE Maxima, which is a cross reference for most parts for my car.
The car handles great, and rides fine, however on moderate to large bumps, it makes a banging sound!
I a have checked the following:
1) Removed items from my trunk, such as several car wax and cleaning products that had a combined decent weight in a bag to make a noise over bumps on the trunk floor board.
2) Tightened down the spare.
3) Checked to see if springs were seated right, and they appeared to be. Springs were still in great condition with no visible nicks on powder coat of banging together?
4)Looked for nicks on sway bar, and checked sway bar clearance and alignment. I cant see or feel anycthing hiting some thing?
This is causing such a pain.
Originally posted by HoJo
Did you cut the bump stops? The car might be bottoming out.
I have to retighten the koni's soon, so i figured id bug someone before i cut anything.. do you hapen to have a picture of them? Im guessin its the rubber thing with ***** or whatever.. kinda like a stretched out plunger thing?
just a thought, who knows right.
sounds stupid....but
When I did mine this week I forgot to tighten the lug nuts down on the left rear. I took a ride and it was fine for about a day. Then it started to make a noise like you describe when I went over bumps and the car was riding horribly.
I started to take the tires off to check the shocks and noticed that the lugs on that rim were finger tight!!!!!
maybe check that?
SHUMAX
maybe check that?
SHUMAX
I think it is in fact bottoming out!? Then what? I had a rather large person with me the other day, and it would do it more often. The exact same sound.
I also ckeched the jack stand. Its tight, won't move. I think I can rule out any loose object doing this from in the trunk.
This really starting to bug. If don't figre it out soon,I will have the stock units put back in. This car is driving like a POS over bumps, not like a 30K+ car. I have not goten it re-aligned yet as I need to solve this first or put it back how it was.
It may be the shocks after all, ande that they don't want to work with these springs? Other then this (which I did) the car has been great, however I'm starting to look at a 330 BMW, manual. That would kinda stink, as I only had this car a few very short months.
perhaps you could try getting the wheels aligned? (even though you said you wanted to solve the problem before getting it aligned, non-alignment could be the problem).
i remember when i first lowered my car, i drove around without alignment and the ride was quite bumpy. however, once i got it aligned the ride quality improved.
Oh Oh Oh Oh!!!!!!
If you don't have a Stillen bar, I don't know what's wrong then...never seen an Addco in person...hope this solves it!
Did you trim the Bump Stops???--->>
I have yet to see you reply to that one...I'm pretty sure that is what it is...
sounds like you may of hit it on the spot, I will look again. My ride is fine, so its not alignment, only over bumps. Anyhow, if this is the problem, what do I do then? Can't move the brackets much.
trim the Bump Stops? What is this? Sounds like something I don't want to do. Please give me more info on these Bump Stops. I've done every mod you can think of, to all kinds of cars, but new to lowering.
BTW, I didnt' cut my rear bumpstops, only the fronts, cuz the rear ones are prett short already..plus, I don't it's the springs either. and H&R Sport springs generally won't make your car buttom out..especially you have a brand new car..no way!!!!(since they don't lower that much in the first place to begin with)
BTW, my car rides less harsh than stock and it handles terrific!!!!no problems so far.
Lakersallday24
Jun 16, 2019 01:35 AM
soon2ownmax
Aug 13, 2015 02:19 PM
kirkhilles
Aug 8, 2015 10:53 AM
laparka66
Aug 6, 2015 09:36 AM
