location of EGR valve
Does anybody know where the EGR valve is located on a 96 max. I want to change it, my check engine light is on because of it . i am not sure where it is located. Does anybody have pics or good info to tell me where it is. It would helpful to me. Also could i use a 99 EGR valve on my car, is it the same thing because the dealer has no i dear just because is has a different part #
What code are u getting?..EGR valves hardly fail.!..this valve is located under TB..looks like a upside down flying saucer.
I agree with knight71, need to know the code to understand, but the valve itself usually is fine. I've see more bad solenoids than bad valves. A hand-vacuum pump can test the valve easily.
You wanted to know where it is located. I tried answering a post just like this for another guy a week ago but couldn't get the hosting to work right... (now fixed!!) These pics are for the 95, but expect it should be close enough.
The red arrow points at the EGR. It is difficult to reach.
well the code i am getting 1005 which is EGRC Solenoid valve. So i am not sure if its the valve or not. I am guessing right now.
So..Replace the solenoid valve..not the EGR valve..no need to replace..Save some $$$ too.
Simply cause you're an ***. My ISP went down at 1:20, few minutes after that post(ORG clock is off by 30 some minutes). After that my dad's car broke down and he needs a new starter/ignition switch so I was in the garage for 5.5 hrs diagnosing the damn problem. Come and see for yourself since you live around here, *******. Next time just shut your hole.
These are straight from the FSM, not the biggest pic but it should give you an idea where it is and what it looks like. If anyone wants I can send a PDF for 1005, or any other problem you have.
Originally Posted by I_EaT_RiCe_ErZ
I have an 0302 code. Is that the code for the valve? According to the haynes manual it says "Egr insufficient or excessive flow detected." When I rev the engine, the valve does not move at all.
Code 0302 is a *****..I had that not long ago...It could mean a # of things..not likely the EGR valve itself..My prob was solved by replacing EGR solenoid valve.
Check the stickys on code 0302...Good luck!!!
shilov
Feb 19, 2024 09:40 PM
