P0400 won't go off
Old Sep 11, 2015 | 06:36 PM
DarjeelingRose's Avatar
P0400 won't go off
I have an P0400 code that won't go off. I have changed the part out and had the pipes cleaned out. BTW the pipes was not clogged or dirty. The mechanic turn off the code. Told me to drive about 40 miles before they would inspect it for state inspection. The light came on at 20 miles. Checked it and the P0400 code came back up.
I don't know what to do. Does anyone have any idea what is going on?
Additional Information
*had a damaged neck filler that was replaced. The light was on before and after
*EGR valve and sensor was just put on.
* Clean out pipes
*all new belts
*new crank shaft pulley
* new alternator
* has all necessary fluids
Last edited by DarjeelingRose; Sep 11, 2015 at 06:47 PM. Reason: additional information
Old Sep 11, 2015 | 09:15 PM
lux97Max's Avatar
One of your catalytic converters could be clogged.
Old Sep 12, 2015 | 10:33 PM
DennisMik's Avatar
Possible causes for the P0400 code are:
- EGR volume control valve stuck closed
- EGR passage clogged
- EGR temperature sensor and circuit
- Harness or connectors (EGR control valve circuit is open or shorted.)
- Exhaust gas leaks
Old Sep 15, 2015 | 01:20 AM
BronxSleeperMax187's Avatar
ive had this code for A while, and noticed that if I put some fuel injector cleaner before A fill up it keeps it off for longer after A reset.
Sep 27, 2015 08:37 AM
msellas
Sep 23, 2015 09:16 PM
followthadollar
Sep 22, 2015 11:53 PM
markevans999
Sep 10, 2015 04:29 PM
