changing brake pads=not as easy as one thought
today i decided to change my back breaks by myself...(i change the fronts b4 and they were an itch too...the caliper nut was stripped)..OK things were going smoothly until i couldnt get the cylinder to go in...i used a big a$$ c clamp and nothing worked...what am i doing wrong...and the brake fluid cap is off e-brake off etc...help thanks.
go to sears they have a little cube that will help you to screw the piston back in. Also there are directions around here somewhere on how to do brakes, I suggest reading them. Also it would pay to have your rotors resurfaced so your brakes wont squeak and you will have better performance.
I stuck a board over the piston and used a C clamp and my piston went in very easy and very straight..... I did notice that my stock brake pads had clips on all 4 and the ones I bought only had clips on 2. Anyone have the same problem?
As for the "clips" are you referring to shims, squeel sensors, or brake pad ears? Youll have to give more info than that.
Originally Posted by Colonel
OK, first off I hope you used the board and c clamp on the fronts, not the backs. I have yet to hear of ANYBODY that could manipulate the rear pistons without twisting, as they are designed that way.
Well
Sorry about the confussion, but I was talking about the front brakes and the brake pad ears.
The ears have to match exactly. Otherwise you have the wrong pads. I know there was a difference made to the rears mid 00-01 production line change...but not sure on the 02+'s
brake ears
Originally Posted by ajahearn
Sorry to hijack this thread but Is this true for aftermarket pads? I noticed the Hawk pads I got only had ears on the outboard pads (these were the fronts). Is it really possible to wear down one pad without the other?
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
