Removing Lowering Springs
Old Jun 24, 2004 | 10:44 AM
mistadee77's Avatar
I'm getting a BMW 540I and giving my girl my 00 Max, I was wondering if I take the lowering springs off the max and put the regular springs on will I need to change my shocks also or can I leave them on there and will they be fine.
Old Jun 24, 2004 | 12:33 PM
MaximaPolak's Avatar
What kind of springs .....?
Old Jun 24, 2004 | 01:23 PM
mistadee77's Avatar
Eibach Springs
Old Jun 24, 2004 | 02:30 PM
ryand.white's Avatar
Want to sell them?
Old Jun 24, 2004 | 05:06 PM
MaximaSe2002's Avatar
the shocks should be fine with the factory springs just a little stiffer
Old Jun 25, 2004 | 04:50 AM
mistadee77's Avatar
I'm asking because I know everyone says that you need to change the factory shocks when you lower the car so I was wondering if it needs to be changed if you go back..
I'm also looking to sell the springs so anyone interested make me an offer. They have been on the car since May 2003
Old Jun 25, 2004 | 07:21 AM
MaxSE03's Avatar
You'll be fine with just changing out the springs.
Old Jun 25, 2004 | 07:32 AM
blkmaxx's Avatar
you selling, im buying
Old Jun 25, 2004 | 07:44 AM
mistadee77's Avatar
Make me an OFFER...
Old Jun 25, 2004 | 07:46 AM
mistadee77's Avatar
So even though I had to change them when I lowered they will be fine once put back to dealer springs?
Old Jun 25, 2004 | 08:47 AM
gsumax's Avatar
do you have stock struts right now?? and if you do, as long as they arent blown youll be fine...
Old Jun 25, 2004 | 09:11 AM
mistadee77's Avatar
I have KYB GR2's in there now.
Old Jun 25, 2004 | 09:26 AM
blkmaxx's Avatar
sent ya a pm
Old Jun 25, 2004 | 09:33 AM
gsumax's Avatar
well your ride will be stiffer than when first it was stock, but the struts will be fine because youll hardly be making them work when going back to stock suspension. The gr-2's are naturally alot stiffer strut.
Old Jun 25, 2004 | 09:48 AM
mistadee77's Avatar
What do you mean by stiffer?
Old Jun 25, 2004 | 09:49 AM
MaxSE03's Avatar
Yep, you changed them to the KYB's to handle the increased spring rate of the aftermarket springs. They should still be in good shape and will work fine with the OEM springs.
Old Jun 25, 2004 | 01:37 PM
Hey....how many miles on the springs.....I'm interested.....
Old Jun 26, 2004 | 07:09 AM
ABS's Avatar
ABS
The KYB GR2 struts are a different design than the OEM strut. The OEM strut offers very little damping with small spring oscillations which helps to create that smooth almost floaty luxury type ride. The GR2 provides a lot of damping with small spring oscillations so you "feel" the road a lot more. The OEM strut gets very firm over big bumps and pot holes. This firmness is a function of piston speed and valving within the strut. The GR2 struts tend to "give" a little more over the big bumps and pot holes. Personally, I did not care for the floaty feel on smooth roads nor the harshness over bumps I experienced with the OEM setup on my 2K2. I immediately noticed the difference in ride feel when I went to the GR2. Don't forget the GR2 is designed to be an OEM strut replacement. It should work extremely well with the OEM springs. What I did notice about the GR2 is that the rears wear out fast when used with lower springs. If you've had the rears on for 25K+ you might consider replacing them when everything is out of the car. Plus, they are pretty cheap anyway. Good luck!
Old Jun 27, 2004 | 05:29 AM
mistadee77's Avatar
Thanks for the input. I've had the KYB shocks on since December so about 8 or 9,000 miles so they should be good.
BkGreen97
Apr 2, 2016 05:47 AM
imported_Nismo_max
Feb 17, 2016 03:39 AM
bumpypickle
Sep 19, 2015 01:07 AM
Hdnseek
Sep 9, 2015 05:55 AM
lowpost99
Sep 8, 2015 05:06 AM
