speaker level to rca converters
is it possible to not cut the factory wiring harness while installing these?
also, what would I use for the remote turn on lead for the amp?
edit: headunit is factory bose unit. the main idea behind this is so I can possibly run an amp for a sub
I have exactly what you need. You can't use the Bose pre-amp level signal because they are a balanced signal.
I always stock these, PAC (Pacific Accessory Corporation) AOEM-NIS2. They plug directly into the back of the Bose head unit and give you two pairs of RCA outs. The signal quality you get out of these does not compare to a high-low converter that uses a speaker level signal and just drops the voltage.
$39.95 shipped.
Regards,
Bryan
bryan@berktechnology.com
Some pics installed on my own car.
$39.95 shipped.
Regards,
Bryan
magiconthetire
Oct 26, 2015 09:03 PM
