Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
When using buffer, which pads do I use for SMR and polish?
Old Jun 30, 2004 | 12:40 PM
95maxrider's Avatar
Lightly modded
Well I have some cheap **** Turtle Wax buffer thing (don't know proper name) and I'm not sure which pads to use for what. I have blue thin ones for applying wax, some white cotton ones for removing the wax, then 2 other ones I don't know much about. One is a yellow foam pad which I *think* is for applying polish, but I'm not sure. The other is an off-yellow color which I *think* I use for after removing the wax to polish it a little bit. I can get some pics if you don't quite follow this. Thanks guys.
Old Jul 1, 2004 | 01:31 PM
MaxSE03's Avatar
The denser of the two is most likely used for light compound and the other for polish. That's my best guess without being able to look and feel them.
Old Jul 1, 2004 | 01:34 PM
95maxrider's Avatar
Lightly modded
For my 3M SMR, it says I can use a foam pad on a buffer if I don't want to do it by hand, which I don't. Does that sound like the foam yellow one I described earlier?
Old Jul 2, 2004 | 07:17 AM
MaxSE03's Avatar
Should be, just can't tell you for sure.
Old Jul 4, 2004 | 12:12 AM
Bman's Avatar
Usually they TELL you what each bonnet is for in the instruction booklet, don't they?
I'd be inclined to use the terry cloth bonnets for all polishing jobs. For hand polishing you'd possibly use a folded terry towel anyway. I am pretty sure the foam bonnet is for dry buffing (not recommended) and you can probably buff off any residues by hand just as well, if not better/faster because you don't have to switch bonnets and towels won't get loaded up as fast.
Not many people seem to know about using these machines to polish because of their many limitations, and foam pad recommendations for the PC don't translate to buffers like these...
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
JonBlz
Oct 5, 2015 06:02 PM
bbsitum
Sep 11, 2015 04:55 PM
