99 spare key options
so, the only key i have is broken, and i'm payen $75 for a new from the dealership. what are my other options?!?
I was thinken of making copies and securing the orignal key under the dash near the ignition so the security chip would still work.
but so far i'v been unable to find spares for the max that'll work.
anyone know where i can find some, specifically
thanks in advance
thanks in advance
Get copies from any hardware store and attach the broken key inside the steering column near the ignition. This will essentially disable that anti-theft measure and make you like all us less sofisticated max owners, but it'll save you a ton on spares.
Been there done that, I tried holding the original key as close to the ignition as possible, but the car would still not start with a copied key, As far as I know, the chipped key has to be inside the accual keyhole... But that's just from my experience..
do you a have clear pic of your fog light?
thinking about doing a custom install with round fog light and some cf blank panel
I lost one of mine too. I know there's a website with these keys (yes, the chipped type) where it costs only $50 (instead of $75+ like they charge in the stealership). This $50 includes:
1) the key, duh
2) the chip inside the key
3) programming of the chip
somebody remember the website name?
1) the key, duh
thanks in advance
thanks in advance
If you can't get it to work buy a DEI 555u alarm bypass. Connect the black wire to ground and the red wire to the ignition wire at the key cylinder. Get $1.00 key copies at Walmart and put the chipped key in the 555u.
Why would you want to disable the anti-theft system, just to have cheaper keys? Mine are expensive too, but I like that nobody can start my car without the key.
I think www.redlinemax.com used to sell those keys that you guys are talking about. Check there. I don't even know if they are still in business or not.
the website is www.streetkeys.com
Now I've relocated the hood release. Screwed in metal straps under the driver dash to prevent access to the ignition wires from below. If someone reaches up there without looking....they're going to peel their arm like a banana. Eww!!
If your car doesn't have an alarm. The moment that the keycylinder is popped out it damages the anti-theft ring and they can't start it anyway because it can't read the coded key. I think you're safe. Hide your key WELL or grind down the teeth on it.
Apr 16, 2020 05:15 AM
