ebay CAI instructions
Old Jul 8, 2004 | 03:42 PM
c0mpletec0ntrol's Avatar
All of the ebay intakes i've seen don't come with instructions... Could anyone show me where I could find installation instructions? I'd really appreciate it.
Also, would you recommend that I buy a better filter for it? K&N?
Thanks a lot!
Old Jul 8, 2004 | 03:44 PM
some of the intakes also said that a small hole has to be drilled... can anyone elaborate on that? thanks!
Old Jul 8, 2004 | 04:31 PM
Keyser Skoze's Avatar
I've installed 10000000 intakes. You dont need instructions. Just look at the pipes and you can take it from there. I only had 1 problem with a 2.5 RS because it went straight into the fender wall... it took a little bit to see it. you should be fine.
Old Jul 8, 2004 | 05:09 PM
ogparjay's Avatar
if you need to go through the fender wall for a CAI you need a dremal and might take awhile if you don't know how to use one. everything else should be self-explanitory.
Old Jul 8, 2004 | 05:52 PM
MDeezy's Avatar
those CAIs that you drill a whole just above the wheel so it can suck in cold air, wont it be sucking in massive amounts of water when it rains
(sorry to distract but wanted to do a CAI setup with the drilled whole but this was a worry)
Old Jul 8, 2004 | 08:00 PM
no problem, man. Do you think i should get a K&N filter with it though?
Old Jul 8, 2004 | 09:34 PM
Tyrexx's Avatar
eventually .
Old Jul 8, 2004 | 09:48 PM
Taken2DaMax's Avatar
**** why don't you buy one now? Those ebay filters work like @ss. Go to autozone and buy one for cheap. The number for the one that ih ave under the hood is RU-2820.
Old Jul 9, 2004 | 01:23 AM
K&N is really good. That ebay crap sucks
Old Jul 9, 2004 | 07:14 AM
GodFather's Avatar
Made in Taiwan
dude, i bought one last week with the instructions but it didnt help, has no diagrams that supposed to come with it. so me and my bro got together and figure it out. it was easy, you don't need the instructions. just line up the pipings and you'll know what to do. the hard part is the drilling of a 3" hole in the fender on the side of the battery right under the small fuse box. man, i did't have a saw or dremel. i only used a drill and had to drill around. it was a bittch. son of a bittch took me 30 minutes to just make a dammn hole. if you need further help , i'll try to go back and prodoce some pix.
Old Jul 9, 2004 | 07:30 AM
CaLSoNiC
Anyone able to scan the template? I need one :P
Old Jul 9, 2004 | 08:20 AM
MadChef's Avatar
https://maxima.org/shoptalk/sub_modi...ai/index.shtml
Old Jul 9, 2004 | 08:47 AM
felix's Avatar
Sittin' On Chrome
i think people install bypass valves for this.
Old Jul 9, 2004 | 11:01 AM
What happens when you slam the car on some 18's? Wont the cone be in the way? I thought about doing this to mine but went with the injen instead. I was going to bring it to my girls mothers job and have them make me one out of polished aluminum using the ebay one as a gide. Just because i like the way the injen shines. But i dont know if the cone will be in the way.
litch
123
Jan 4, 2024 07:01 PM
magiconthetire
Oct 26, 2015 09:03 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
Sep 27, 2015 08:37 AM
