need help with nitrous setup
Old Jul 11, 2004 | 11:26 AM
vq30max's Avatar
i hooked up my nitrous and everytime i try to punch it feels like my motor is going to shut off.....im pretty sure its my fuel line.....i tapped into the fuel line where the fuel pump is... after the fuel pump is where i put the tee......is that where i need to put the tee??? or did i tap in the wrong place????
Old Jul 11, 2004 | 04:34 PM
Jime's Avatar
"after the fuel pump"?????
It should be between the filter and the fuel rail. If thats what you mean by "after the fuel pump" then yes that is the correct spot.
I hope you didn't put it after the FPR which is on the discharge of the fuel rail.
Old Jul 21, 2004 | 09:22 PM
venompwr2's Avatar
Are you talking about a tee for a wet kit, or the vacuum tee? which doesnt actually go into a fuel line, just air.
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
knight_yyz
Nov 6, 2015 02:34 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
