Whats the problem??
Old Jul 21, 2004 | 01:34 PM
kdharris's Avatar
Whats the problem??
What is this a symptom of? I have a 2000 max se with 100000k mikes on it. It has decent low end acceleration, but when I floor it the rpms go up but nothing else happens, it is like it is cutting out! It has been doing this for several months. I changed my plugs a few weeks ago hoping this would help but it didnt. Is this a MAF problem or what? How much is a new one?
Thanks for advice!
Old Jul 21, 2004 | 01:41 PM
SoonerFan's Avatar
Cletus
if the RPMS are going up "it" (engine) isnt cutting out. sounds like a tranny problem (the power isnt getting to the wheels) do yo have an auto or 5 speed?
Old Jul 21, 2004 | 01:42 PM
schmatt's Avatar
WOW...a hundred million miles on your car? I didn't think that was possible...now i'm really impressed with nissan.
What are exactly trying to say? It sounds like your car won't even move? You need to describe these symptoms better. What exactly are you talking about? Does it stall? Does it have poor acceleration? Give us some more details on the problem.
Old Jul 21, 2004 | 01:45 PM
SoonerFan's Avatar
Cletus
i just noticed the "K" at the end of that
Old Jul 21, 2004 | 02:53 PM
kdharris's Avatar
It is a automatic.
When I crank it up in the a.m. it idles fine but when I give it gas it has some hesitation this only last 30-40 seconds and it goes away. If I am at a dead stop and floor it is has great acceleration up to about 4k (four thousand) rpms and it does not pull anymore. I am still accelerating but not like I should at that rpm. The engine seems to stall at high rpms, It does not make since for it to be the tranny, why would it only slip at high rpms?
Old Jul 21, 2004 | 03:39 PM
SoonerFan's Avatar
Cletus
well you decribed it diffirent this time...ITS THE MAF
Old Jul 21, 2004 | 05:10 PM
Progress's Avatar
It's business time.
That is the same exact symptom that my car had. If you have an extended warranty get a new MAF. If you don't, buy one for under $100 and install it yourself. It's really easy. Your car should run as new after the replacement.
Old Jul 26, 2004 | 01:48 PM
kdharris's Avatar
Thanks, I hope it works
Old Jul 26, 2004 | 01:57 PM
dgmaxse's Avatar
My 2000 max with 80k has the same issue, I figure I'd post this question at some point, glad you beat me to it. I'll try the MAF change, thanks.
Old Jul 26, 2004 | 03:00 PM
GeneYes_Se5spd's Avatar
Does anyone know how to diagnose this problem with a volt meter? can you check the resistance and compare it to the factory specs to see if you car has a bad MAF? In my volvo the part was a 2 titanium wires that when air passed across them cause their resistance to fluctuate depending on the velocity and temperature of the are , thats how the computer knew how much fuel and what mixture to spray from the injectors. Is that how this one works also?
Gene
Old Jul 27, 2004 | 09:34 AM
schmatt's Avatar
Yes, you can do a diagnosis of the MAF with a voltmeter. Refer to the factory service manual for more info on that. I'm not sure how hard it is though. It refers to using the CONSULT-II system, but you could probably figure out a way to do it without this. You are only looking for the signal change in the MAF.
Anyway, I didn't bother and just replaced my MAF when I had cold engine hesitation. Went away with new MAF.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
