Double Checking... I should NOT get a ecu upgrade if I want Nitrous
Originally Posted by DaBombX
Right? Cuz the advanced timing on the upgraded ecu will cause detonation when nitrous oxide is sprayed.
doesn't mean you can't run some form of fi if you have a modified ecu though. I have a TS ecu and am waiting on my nx wet kit. You just need some means of retarding timing. A couple of ways I know of:
jwt "nitrous" ecu as mentioned above. This is an ecu with the typical advanced timing and modified fuel map that TS also does, but a daughter card is thrown in to retard timing back to stock on nitrous activation. Costs a few hundred more than a regular jwt modified ecu. Not worth it imo because if you later want to go turbo/sc you have a very expensive and useless ecu.
Better to get a J&S Safeguard. Retards based on knock detection and retards per cylinder. With the Safeguard you have so many options on how you want timing retarded. I hope I have no problems installing this sucker.
worldwiderecognized
Sep 30, 2015 01:16 PM
