Timing belt questions
1) Do you really need a holder to remove the cam pulley or can you improvise with a screwdriver, strap wrench or other?
2) Do you really an installer to install the cam/crank seals or can you improvise or make your own?
Thx for replies
Thx for replies
Ummm, with all due respect... if you have to ask these questions, you should probably let a mechanic handle it.
the proper answer is no... just do whatever's necessary. when I pull the cam sprockets loose, I do it before removing the timing belt. I just leave a breaker bar on the crank pulley and pop the cam bolts loose, then snug them up so the pulleys don't wobble while I'm removing the belt.
for the seals, I just use big sockets the same size, or the old seal I pried out with a hammer. never had a problem.
Hondarydr
Dec 30, 2024 06:15 PM
tsi6001
Oct 3, 2022 10:23 PM
JMag90
Aug 25, 2015 09:17 AM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
