problems with my 88
problems with my 88
i have an 88 max i've just bought back from a buddy. he hurt it pretty bad. i replaced the mass air and the cylinder head temp sensor. those codes are gone and now she runs, but i have a code 22 fuel pump circuit code. it runs really bad cold and when it warms up it runs ok but the idle is really rough and it is lacking a bit of power as well as blowing some black smoke. i don't know what is causing the fuel pump code. i had the injector recall done last year and i tested the fuel pump, it has excellent pressure. the haynes manual is very vauge on what it could be. if you guys could help me out i'd be greatful. thanx.
Since the fuel pump is good, the next place to look is the actual connector in the trunk of the car. Test the upper left port on the female side. Just ground and check for continuity with a multimeter.
Heres the thing the symptoms are either the Idle speed control valve circuit is open or short. Fuel circuit is open or short. So it might be electrical. I personally have no Idea how to fix that. So hopefully something isn't connected correctly and you just need to connect them. Hope this helps
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
