O2 sensor code will not go away
I have a 98 GXE, and every several thousand miles I throw the same code 04 09. Which is the O2 sensor on the rear (closest to fire wall) branch of the Y-Pipe...someone please correct me if I am changing the wrong one. I have now replaced the sensor twice since I have had the car and I have only put about 40K on the car. Am I changing the proper O2 sensor for this code..and if so what in the heck is causing this problem? Also when I replace the sensor I have always used the Bosch OEM. Thanks for your help.
-Carson
-Carson
well i got my obd2 scanner today and i checked the code and it ended up being p0153 which is 0413 on the cel method....i also checked the readings on the bank 1 sensor 1 and it was all screwed up so i think i found the cause of the cel but i dont know y the cel method was giving me 0409 instead of 0413....very weird hopefully when i change this sensor no more cel
is there some sort of re call for this? I dont have any sort of warranty left on my car that I am aware of.
Originally Posted by PAREDLINE
Call Nissan and see if your Emission warranty is still valid. Might be your computer
220k+ A32
18
Sep 22, 2015 11:39 AM
