Just nailed 14.1 @ 97 mph in my automagic
Wondering where this puts me amongst the drag racers here... havent been on the org a lot this summer, lost track of people. My only mods are cat-back, UDP, GAB w/K&N filter. Also used drop resistor mod.
Times for those interested:
r/t: .703
60': 2.153
330': 5.966
1/8: 9.117
MPH: 78.49
1000': 11.842
1/4: 14.162
MPH: 97.05
Not bad for the old automatic!
r/t: .703
60': 2.153
330': 5.966
1/8: 9.117
MPH: 78.49
1000': 11.842
1/4: 14.162
MPH: 97.05
I shifted it. right up to redline for all (well both) my shifts. No, never done a dyno run... thought about it, but figured it wouldnt do me all that much good cause i dont have anything to tune...
Great Time!!
That is a great time for an auto with those mods, especially a GLE. Has anyone noticed that GLEs seem to be a little slower? or not. I have talked with several people with GLEs and all have consistently said that they have kicked it down against SEs of the same year and driveline (auto) and the SE will put a little distance on them.
I ask if anyone knows if there is any difference in the ECU or programming logic for the auto. I realize that the hardware is the same.
When I ran that time it was around 70 degrees with fairly low humidity. Very good weather for dragging. My next run the temp was down to 62 degrees (like 1.5 hours later) and i couldnt hook up. Ran a 14.4 but trapped at 97.5! My 60' on that one was 2.3xx tho.... oh but soooooooooo close to 13's. so close
I've raced an SE auto at the track before and I put distance on him thru 1st gear (my only mod was an UDP - thats most likely the reason). Then it was dead even. Like a mirror image of my car racing in the next lane.
At least I have someone to test against easily.
Originally Posted by MAXINXS
That is a very good time. How in the hell are you hitting 14.1 at 97 when I am trapping at 100 mph and getting a best of 14.2? What's your secret?
thats the way to hold it down for us automagics. trust me from one automagic to the next those are some incredible numbers. heck it took a s/c for me to reach those numbers imagine if you had one, good work
nice times man my best was a 14.6 at 94... this was with a cat back and JWT pop charger. my question to you is when you manualy shiffted you said you brought it all the way to redline did you keep the pedal to the floor while shiffting or did you lift off the gas then shift?
kept it on the floor. to avoid goin past redline and bounchin the rev limiter, you gotta shift a tad before the tach says you're at redline. There is a slight delay between you shifting and the car responding. Also do the drop resistor next time you go, I bet you drop at least 1 tenth
Originally Posted by wngan9447
I know I'm sounding like a newbie here, but whats the drop resistor?
on 5th gens it is located in the same spot. I do NOT recommend driving around daily with this modification though, as it shifts way too hard. Only for WOT circumstances (such as 1/4 miling).
and thanks, ripper! now if only I could join the 100 mph club like you've done...
Ya, maybe next year. Should still have the Max - hoping to pick up a crotch rocket in the spring too, but that shouldnt hinder dragging the Max.... Wish I had a video of a couple of my runs, but my buddy who was gonna video didnt show up till like 9:15 or so, not quite enough time to get set up to video. Well, I'll be there again in the spring mostly likely. Will catch up wtih ya lata man!
Apr 16, 2020 05:15 AM
